k&n typhoon intake problem
Old Feb 5, 2006 | 02:10 AM
scionmartin's Avatar
Default k&n typhoon intake problem
hey all i put on my intake this friday...all went smooth until the check engine light and the trac off... and vsc light came on... i dont know what to do... anyone got any ideas..... on what i can do to get this problem fixed.... i would really apreciate any imput
Old Feb 5, 2006 | 02:15 AM
Hot06tC's Avatar
Put your OEM intake back on, and take it to the dealer.
Old Feb 5, 2006 | 02:58 AM
frogbox's Avatar
Re-set your ecu, mine did the same thing. Also make sure your MAF sensor is clean, sometime they come with too much oil on them and foul the sensor
Old Feb 5, 2006 | 04:24 AM
hmmmm..... how do i clean my maf... with what do i use????
Old Feb 5, 2006 | 04:37 AM
jct's Avatar
jct
use this site it'll help ya thru
http://groups.msn.com/Sorensonbrian/...rcleaning.msnw
Old Feb 5, 2006 | 05:10 AM
aight..... and if that doesnt solve it does anyone else have any ideas?????? cuz i am stumped.... i have no clue what to do.....
Old Feb 5, 2006 | 07:42 PM
TheScionicMan's Avatar
Do that first before we try to move forward. \
Did you wipe the inside of the intake out before you installed it? Many of them have residue and stuff inside that can foul the MAF.
WIpe the inside out as best you can. clean the MAF, let it dry, reset the ECU. After you restart it, let it sit and idle for 10-15 minutes with an occasional revving of the engine. This will let the ECU recognize the difference in the intakes. Then take it for a drive and report back to us.
Old Feb 6, 2006 | 05:19 AM
DUB_BUS's Avatar
I had the exact same problem...it when for about a month untill I called K&N and they called me in to the R&D department ,they keep my car for the day but gave me a 05 magnum to drive...they said they needed put hose clamps on both ends of the crank case breather tube because it was throughing off the o2 mixture...they put the clamps on and 9 months latter not problems and 37mpg on 20'' rims...
Old Feb 7, 2006 | 12:56 AM
proctorsilex's Avatar
These intakes have a ton of crud inside them, even name brands.
I found a few large flakes of metal in my Typhoon. Listen to TheScionicMan: make sure that you wipe that thing out even if you've fixed the problem.
My Typhoon came with clamps for the crank case hose. I can't remember if I was missing one or if I just liked the squeeze kind better, but I used a squeeze clamp on the intake end and o-clamp on the engine end. The o-clamps can tighten that tube to what looks like way too much.
Good luck!
airmankevin1
Feb 14, 2018 01:23 PM
Marganne
Apr 3, 2015 06:52 PM
Scionxa180
Mar 13, 2015 04:39 AM
AxRxP
Jan 25, 2015 08:40 PM
stankubrick
21
Jan 4, 2004 06:30 PM
