amp power question......
Old Feb 12, 2006 | 10:56 PM
lppro-xb's Avatar
Default amp power question......
ok i have a 600 watt mono amp for my subs (2 alpine 10's) and i want to but this amp,
http://www.woofersetc.com/index.cfm?...roduct_ID=2342
for my door speakers. so the question is can i use an 8g cable into a distribution block,
http://www.woofersetc.com/index.cfm?...roduct_ID=2773
then into both the amps?
p.s. dose anyone have any experence w/ woofersetc.com ? good/bad?
Old Feb 12, 2006 | 11:06 PM
chadfo's Avatar
I wouldn't use Boss Audio. It's cheap junk.
You can wire it like you mentioned.
Old Feb 12, 2006 | 11:17 PM
lppro-xb's Avatar
so your saying boss dosent sound as good as a more expensive name?
Old Feb 12, 2006 | 11:21 PM
violent_b's Avatar
in car audio, you get what you pay for. with amplifiers go with the most power (rms power not max power) you can afford.
Old Feb 12, 2006 | 11:24 PM
chadfo's Avatar
Not from what I've heard. Mostly it's a problem with reliability.
I'm not saying you have to buy the best thing on the market but get something that sounds good and you can depend on.
Old Feb 12, 2006 | 11:29 PM
lppro-xb's Avatar
what do you sugest? (on a low budget)
Old Feb 12, 2006 | 11:52 PM
lppro-xb's Avatar
http://www.woofersetc.com/index.cfm?...roduct_ID=2737
or
http://www.woofersetc.com/index.cfm?...roduct_ID=3029
are these good?
Old Feb 13, 2006 | 01:13 AM
chadfo's Avatar
http://www.onlinecarstereo.com/CarAu...roductID=14796
http://www.onlinecarstereo.com/CarAu...roductID=14870
http://www.onlinecarstereo.com/CarAu...roductID=15525
http://www.onlinecarstereo.com/CarAu...roductID=14688
Old Feb 13, 2006 | 01:22 AM
lppro-xb's Avatar
thanks for all the help chadfo
Old Feb 13, 2006 | 02:41 AM
mal75's Avatar
You're going to need at least 4 gauge wire going to you distribution block and 4 gauge to your 600 watt amp. The smaller amp will be ok with 8 gauge.
Old Feb 13, 2006 | 03:57 AM
Spr0ket's Avatar
If you are going to run subs, I would highly recommend finding a decent class d amp even if that amp is only 150W. The signal will be cleaner and not as sloppy making the bass sound tighter or more acurate. Here's a very cheap unit you can find (lowest price I've seen is $75 on ebay new in box).
http://www.onlinecarstereo.com/CarAu...facturerID=625
Another option would be to find a really good 3-channel amp and power the subs and just the front. Then you could save up some money for a great 4-channel amp to bi-amp the components in the front using the old 3-channel for the subs and rear. That will save you some money up front and give you a better system down the road.
Old Feb 13, 2006 | 05:06 AM
FREQBOX's Avatar
I disagree about the class D amp being cleaner they actually tend to have alot more distortion than a class A/B but they do make more raw power in a smaller package, thats why they are used for bass applications were distortion isnt as easily heard or recognized as distortion.
I have tested ( in a previos vehicle) a few different class D bass amps against an A/B of equal power and would take the A/B anyday...but i wasnt on a budget so that might make a difference
Old Feb 13, 2006 | 06:06 AM
Spr0ket's Avatar
I like the class D amps better for low end. Yes you can do the A/B amps but you're more or less throwing away money for a section of frequency you will never use. Class D will be good from the bottom end to about 200Hz or so before distortion really kicks in. If you have a sub that is playing 200Hz, you need to reset your crossover points.
Old Feb 13, 2006 | 04:08 PM
lppro-xb's Avatar
i all ready have the subs and mono amp hooked up with an 8g power cable they work fine my question was can i use the same 8g cable into a distribution block then to both amps with another 8g cable w/ Capacitor.
Old Feb 13, 2006 | 04:19 PM
TheIcon's Avatar
Yes you can have 8g in 8 g out of the distribution block. Most distribution blocks fit 4-10g in and 8-10g out. Just look at the in-out size of the distribution block.
Old Feb 13, 2006 | 06:16 PM
ProshopXB's Avatar
If you want to starve your amps of power or blow the fuse under the hood then use 8 g for both, but you would be better off using 4 g in to the distro block then running 8g to each amp, make sure they are short runs for the 8g, that is the minumum i would run. I know money does not grow on trees but your best bet would be to run a 4g to your mono amp and atleast an 8g, depending on the amp you get's power, to the mids and highs amp or get an 0 guage and distro to 4g so if you ever upgrade amps. Always better to plan ahead it will honestly save money in the long run. As for the amp you want to buy, name brands are always the best, customer reviews is allways a nice thing to read and guage facts on the amps and people that have owned them before, or consulting professional car stereo intallers like Violent B and i are and im sure alot of other guys on here are, cause we will never steer you wrong and we do this on a daily basis.
Old Feb 13, 2006 | 07:08 PM
TheIcon's Avatar
How is running 8g in and 8g out going to blow a fuse?
I agree though should always plan ahead. I would always start with atleast 4g wire leading to my battery. That usually allows for growth in time.
Old Feb 13, 2006 | 07:27 PM
ProshopXB's Avatar
Well if he is trying to pull to much current threw his fuse it will blow,melt etc., unless he puts a bigger fuse in then he could melt his power wire and open a whole other can of worms. Dont do it at all is my advice, spend the money and do it right. Or your vehicle could pay the ultimate price.....
Xaphoon
Scion tC 2G ICE & Interior
Apr 22, 2015 02:36 PM
stillcole
Apr 6, 2015 03:42 PM
TheSilencerTC
Feb 24, 2015 04:56 PM
cwong1001
Dec 3, 2014 03:30 AM
crystaljukebox_com
Feb 5, 2004 05:53 AM
