Headlights staying ON problem...
Old Apr 23, 2006 | 09:44 PM
JJBlaze's Avatar
Default Headlights staying ON problem...
Sup,
My xB just hit 5000 miles and yesterday when I went to turn off the lights the fog lights stayed on. I couldnt get them to turn off.
I had to pop the hood and disconnect one of the headlights for it to shut off.
Anyone know what could cause this and how can I fix it?
Thanks
Old Apr 23, 2006 | 11:29 PM
ack154's Avatar
You don't have a separate fog light switch?
Old Apr 24, 2006 | 01:17 AM
Tomas's Avatar
Admin Emeritus
Hmmmmmmm... If connected correctly the fogs should have a separate switch and a relay which allows them only to come on with the low beams. If yours isn't wired like that, that's your problem.
If it *IS* wired that way, per Scion specs, using the built-in factory wiring with the switch on the dash and the relay in the fuse block, then something is energizing the relay when it shouldn't be. Sounds like a short of some sort.
http://tijil.org/Manuals/Installatio...xBFogLamps.pdf
Good Luck!
Tom
DannyBoy65
Sep 21, 2015 06:23 PM
gqdabien
Sep 17, 2015 09:23 PM
Renuco612
Sep 16, 2015 09:01 AM
umnitza
Sep 1, 2015 08:06 PM
umnitza
Aug 21, 2015 12:35 AM
