Should I be using STP gas treatment?
Old Jun 1, 2006 | 11:13 PM
TongMan's Avatar
Default Should I be using STP gas treatment?
I have been using like 4 bottles of these when I filled-up at the pump. Is this a good idea on a new car?
EDIT: It seems I worded myself wrong. What I meant was that I have used up a total of 4 bottles of gas treatment, NOT at once. I used one bottle every other time that I fill up. Hope this clears things out a little. I know now that it is not necessary to use this.
Old Jun 1, 2006 | 11:31 PM
ack154's Avatar
I don't think it's even necessary to use one... why would you even use 4 though?!
Old Jun 2, 2006 | 12:39 AM
krdshrk's Avatar
4?! I think that would kill your gas mileage. You're essentially putting in MORE alcohol than the small percentage of ethanol that's already in the gas.
Old Jun 2, 2006 | 01:38 AM
jpjxa's Avatar
Oh-No! Please don't! The alcohol content is way more than your fuel system is designed to handle on a every tank basis! It could cause damage to the rubber and plastic parts. It won't hurt to use "ONE" bottle every 3,000-5,000 miles to keep your fuel injectors and intake valves clean. Just don't over do!
Old Jun 2, 2006 | 01:42 AM
jct's Avatar
jct
yes every oil change you should put in "ONE" bottle in of stp injector cleaner
Old Jun 2, 2006 | 01:57 AM
TongMan's Avatar
okay i will stop. I never knew to use it only every 3000-5000 miles.
Old Jun 2, 2006 | 03:54 AM
krdshrk's Avatar
... It says it on the bottle!
Old Jun 2, 2006 | 03:59 AM
OldYeller's Avatar
come on--reading bottles and directions is for women!!!!
Old Jun 5, 2006 | 01:30 AM
bB2NER's Avatar
Music City Scions
one bottle every 5, 000 miles is cheap insurance against dirty injectors.
Old Jun 6, 2006 | 01:50 AM
flyerI's Avatar
Red the directions. It may say that one bottle will work for as much as a 20 gallon tank. If so you would only need about half a bottle every 3-5 thousand miles. Too much will do bad things to the components in the fuel system. I use Lucas Upper Cylinder Lubricant. It has an injector cleaner and fuel conditioner in it. It is thick and oily compared to the STP product and seems to do a good job. The oil is good for the fuel pump and gives some top valve lubrication. You use 3 oz per 10 gallons of gas.
Old Jun 6, 2006 | 03:04 AM
Tomas's Avatar
Admin Emeritus
One I like is the Chevron Techron cleaner/additive and since it is used in all grades of Chevron gasoline, and I use almost exclusively Chevron gasoline, I doubt I need a whole lot of additional 'mouse milk' added to the fuel.
If I ever do end up having to use a bunch of non-Chevron gasoline, I suspect I will toss in a bottle of additive to make sure things are clean when I get back to using the Chevron again.
Whatever one does though, keep in mind that many additives contain a lot of alcohol, and Toyota/Scion has set a MAXIMUM LIMIT OF 10% ALCOHOL for use in our engines. Many of today's gasolines already have 10% alcohol in them as part of their standard formulation, especially in colder weather. Adding large quantities of an alcohol-heavy additive to a gasoline that is already at 10% alcohol exceeds the absolute limits set for our engines.
yupinmytC
22
Jul 27, 2024 07:08 PM
BlingSlade
Nov 20, 2015 06:56 PM
mxwes
Aug 30, 2015 09:11 PM
JymmyTheSaint
Aug 26, 2015 03:44 PM
