OEM Springs or any other springs
Old Jul 14, 2006 | 06:35 PM
itsme's Avatar
Default OEM Springs or any other springs
has anyone cut there stock springs or any other springs and have pictures of how the drop is and any feedback from the experice?
Old Jul 14, 2006 | 07:19 PM
trdsparks's Avatar
Do not cut your springs........ever! They'll never be right and you'll end up buying another set anyway. there are alot of threads out here that tell horror stories.
Old Jul 14, 2006 | 07:46 PM
itsme's Avatar
give me a horror story i wanna hear one well i have like two sets of springs soon to b three and im thinkin bout cuttin the third set
Old Jul 14, 2006 | 07:56 PM
trdsparks's Avatar
OK well in that case. Your vehile will more than likely not set even on all 4 corners. You will lose the spring rate on the spring, there will probably be sagging, it will be super bouncy, and you could actually danage the rest of the suspension. I.E. control arms, end links, tie rods and the steering if it isn't done properly. To be honest there really isn't any way to cut a spring properly. Like I said before there are tons of post on the form about cutting springs. Matter of fact there's on on the fron page right now.
Old Jul 15, 2006 | 07:20 AM
xmetalx's Avatar
spend 140 dollars on some nice springs n00bz.
Old Jul 16, 2006 | 05:55 AM
bB2NER's Avatar
Music City Scions
For one cut springs will fall out on the rear unless they are tack welded into place. 2. They will pop out of position in the front cause the spring pocket doesn't heve the right ramp angle after the first lower coil is cut.
An easier/safer way if you don't want to buy springs is to buy some spring clamps and clamp 2 coils together to achieve a drop for much less. It will leave the mounting points alone so the springs won't fall out or shift during operation.
Old Jul 19, 2006 | 07:16 PM
itsme's Avatar
thanks jethro b i just wanted to know what would happen.......and as for xmetalx i got springs so dont call me a nooob.............i just needed some info...........da onlee time im a noob is when im playin Halo2 online
killahXB2
Mar 27, 2015 10:45 AM
Renike
Mar 1, 2015 10:40 PM
Cadillac15
Jan 29, 2015 07:34 AM
fluxingnation
Dec 26, 2014 04:28 PM
hydrogen
Oct 29, 2003 04:58 AM
