e-brake help!!!
Old Aug 2, 2006 | 02:12 PM
peterbilt's Avatar
Default e-brake help!!!
come on ScionLifers! I know someone out there can help me.
my e-brake is functioning, but not enough to stop my ride from rolling. here is some background:
I had OTG shims - then I got some different rims and took the shims off. nothing wrong w/ them, just too wide for the new wheel setup. everything, I mean everything, went smoothly on the un-install. but as soon as I dropped the car off the jacks after mounting the new wheels, no e-brake.
I pulled the rear hubs and checked that the cabel is pulling the spring - it is. it just seems to not be pulling it far enough to push the pads out to the drum.
any help? any adjustments I can make to the cabel or springs or the brake assembly?
thanks in advance. I've never had much of a delay in finding stuff out here on SL. "I love you man"
p.s. I just remembered that I forgot to check the search button. sorry.
Old Aug 2, 2006 | 03:15 PM
frogbox's Avatar
Remove the center console
Pull E-Brake up 3 clicks
you'll see the lock nut and adjusting nut just under the handle
Tighten down adjusting nut, re tighten the lock nut.
thats what the manual says ( just about)
make sure your brakes are adjusted out back before trying this
Old Aug 2, 2006 | 07:26 PM
peterbilt's Avatar
thanks, dude. I think you may have hit on it. but, if not - you made me think about the problem and it's source. so I think I got.
Old Aug 2, 2006 | 08:46 PM
hayalex6's Avatar
the ebrake sucks, and only 2 of the wheels actually have the parking brake on them (rear drums).
don't believe me? jaack up your car, with ebrake on, and try to move your front wheels, it's so easy, then try the rear, and it's alot more difficult.
Old Aug 2, 2006 | 08:52 PM
RTon20s's Avatar
So what? Go jack up just about any car you have ever owned, driven, ridden in, or seen. Almost all of them only have the parking brake in the rear. And that is sufficient to hold the car in almost all circumstances.
Old Aug 2, 2006 | 09:37 PM
hayalex6's Avatar
this is the first car that happens with me. dunno.
Old Aug 2, 2006 | 11:25 PM
jct's Avatar
jct
what car has a 4 wheel e-brake???
Old Aug 3, 2006 | 12:20 PM
flyerI's Avatar
It is not an emergency (e) brake. It is a parking (p) brake. And hayalex6 is right, parking brakes on rear wheels only on every car and light truck I can think of. There may be an exception and possibly trucks with air powered brakes may lock all wheels when p-brake is applied.
Old Aug 3, 2006 | 04:51 PM
D_M_A_N's Avatar
isn't e-brake, p-brake, hand brake same on our rides? if not what the diff?
Old Aug 3, 2006 | 06:37 PM
jct's Avatar
jct
its the same thing really
when your brakes go out then its called a e-brake
Old Aug 3, 2006 | 08:37 PM
flyerI's Avatar
As light as our cars are it would probably serve in an emergency. On heavier cars it will not do very much. My truck for example has rear disks and the p-brake is actually a very small drum arrangement inside the hub/brake rotor. It is not powerful to stop snot from running. It will assist the tranmission parking paw when it is Park. The manual refers to parking brake, not e-brake. It is just a matter of words, no big deal really.
Old Dec 7, 2006 | 05:53 AM
Taugenichts's Avatar
I love how heated discussions become when it all comes down to semantics...
Staying on topic... thanks for posting the quick DIY frog box.. never thought to look in the manual for something like this but mine really needs it...
Old Dec 7, 2006 | 08:25 PM
wanachat15's Avatar
hate my e brake. doesn't hold squat. sloppy. had to tension it many times. and still sloppy. any hydralic e brakes out there?
Old Dec 9, 2006 | 03:36 PM
frogbox's Avatar
Depending on how mechanically inclined you are, you could always install a line lock into your rear brakes.
used to have one on the front of my '69 GTO for "warming" up my tires for racing.
it held the front, but left the rears to spin freely, causing alot of smoke, warming the tires for better track grip.
I guess you could just put one on the rears to use as a heavy duty parking brake.
Old Dec 9, 2006 | 08:52 PM
wanachat15's Avatar
or at least i want to try and find hydralic e brake instead of cable. or may be just go and try find a rear disc conversion.
Daskid
Scion tC 1G Aero & Exterior
16
Mar 9, 2007 05:01 PM
lowdownthrowdown
Scion tC 1G ICE & Interior
Dec 5, 2006 01:36 AM
uber-xA-RS2
Jan 24, 2006 08:15 PM
PunkInDrublic
Sep 6, 2005 12:59 PM
rolex87
Oct 2, 2003 04:31 AM
