So there are these two bolts...
Old Aug 13, 2006 | 07:10 AM
mike6789k's Avatar
Default So there are these two bolts...
If you look at where your spare tire is, to the right of that there is a big styrofoam block, take that off and look right where the back of the rear passenger seat is. There are two bolts there that I'd like to use for ground; however, they are EXTREMELY TIGHT!!!
Should I try loosening one up? What do these go to and do I need to tighten it back to a specific torque???
Thanks alot!
Old Aug 13, 2006 | 11:45 AM
2_tC's Avatar
The 2 bolts are from the rear seatbacks. You can loosen them, but like you said, they're on tight. Not sure about torque specs, I'll look it up when I get home.
Old Aug 13, 2006 | 03:17 PM
PghtC's Avatar
Are they the 2 silver nuts? Those are the rear strut nuts, adn they are also very tight. I used one of those to ground my amps. Working fine thus far.
Old Aug 13, 2006 | 09:55 PM
mike6789k's Avatar
How tight did you tighten it? And where can I find torque specs?
Old Aug 13, 2006 | 10:04 PM
mike6789k's Avatar
Ok it says they are at 59 ft-lbs... What will happen if I remove one, put it back on and make it as tight as I can :}
I have no torque wrench
Old Aug 13, 2006 | 11:19 PM
PghtC's Avatar
Make it TIGHT. 59 lb-ft is pretty tight. Just make it nice and tight and you won't have to worry.
Old Aug 13, 2006 | 11:27 PM
KoshiLe's Avatar
yeap iam using those for grounding as well. I tested it with a volt meter. Very little resistance! So it works great for grounding.
Laguna14
Apr 11, 2014 05:33 PM
surfcitylocal
Scion iQ Aero & Exterior
Jan 22, 2013 01:22 PM
myr6goesfast
May 11, 2012 11:16 PM
ack154
Apr 6, 2012 10:48 PM
oblivionlord
Jul 28, 2011 01:37 AM
