Front Door Speaker Baffel Template (Created In Illustrator)
Old Aug 24, 2006 | 06:27 AM
daxII's Avatar
Default Front Door Speaker Baffel Template (Created In Illustrator)
Hey guys, I'll be doing an all-Alpine install in my 2007 tC this weekend and thought I'd post this front door baffel template for anyone else in need. Gotta love the pen tool in Illustrator...Anyway, the cutout diameter is intended for an Alpine Type-R mid, but it should be usable in plenty of other applications with a diameter of 5 3/4". I'm sure a round rasp file would do the trick if you need to bore out the diameter a little more and a conservative cut would allow you a smaller diameter cutout with some wiggle room for filing out a perfect fit. I did a fitment check after cutting out this baffel and everything lines up great. Hope this is of some use!
http://www.technikota.com/sciontctem...007sciontc.pdf
Old Nov 14, 2006 | 06:44 AM
guerro's Avatar
Not Found
The requested URL /sciontctemplate/frontbaffel2005_2007sciontc.pdf was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Old Nov 14, 2006 | 09:01 AM
azynboy55's Avatar
yeah the pic. isn't showing
Old Nov 15, 2006 | 02:33 AM
Tripmasternc's Avatar
Had to make those for my tc, I just drilled the stock speakers out, put then on top of a 3/4 inch piece of MDF, traced around, cut them out and bling I was done....takes a while put it's the only way to go...
Old Nov 15, 2006 | 02:49 AM
guerro's Avatar
What are you talking about ? Can you see the image that the first post links to ?
Old Nov 15, 2006 | 07:49 AM
Deathwish238's Avatar
Dead link
Old Nov 15, 2006 | 08:00 AM
guerro's Avatar
Originally Posted by WeaponX6X
Dead link
Thanks. Wouldn't have ever known unless you posted that.
Old Nov 15, 2006 | 08:46 PM
gompka's Avatar
would be nice if someone posted up a template though so i can get mine done without taking the door off twice
Old Dec 29, 2006 | 09:29 PM
rub3414's Avatar
has anyone posted a link to templates for speaker baffles
Old Dec 31, 2006 | 12:56 AM
azynboy55's Avatar
haha i don't think the guy remembers about his own post...
Old Jan 2, 2007 | 02:18 PM
rub3414's Avatar
yea i noticed. oh well
Old Jan 2, 2007 | 02:30 PM
chrischoi's Avatar
still doesn't work
Old Jan 2, 2007 | 02:36 PM
rub3414's Avatar
i just made my own made out of .5" mdf for the rear the front are mor of a hassle to take everything apart thats y im trying to figure it out before i do.
Old Jan 3, 2007 | 03:01 AM
guerro's Avatar
This is the template I just used to install my fronts. Worked perfect and all the mounting holes lined up. Only thing I had to do was enlarge the opening for the speaker as my iD 6500's were slightly larger than the opening created by the template.
http://sweb.cincinnatistate.edu/mjmo...rontbaffel.pdf
DaBlackBox
134
Apr 10, 2022 02:04 PM
corbmonster
Jan 24, 2015 05:22 PM
yanges
30
Feb 11, 2004 03:49 AM
yanges
13
Nov 29, 2003 10:37 PM
shaefner
Oct 8, 2003 02:48 PM
