Front Door Speaker Baffel Template (Created In Illustrator)
Hey guys, I'll be doing an all-Alpine install in my 2007 tC this weekend and thought I'd post this front door baffel template for anyone else in need. Gotta love the pen tool in Illustrator...Anyway, the cutout diameter is intended for an Alpine Type-R mid, but it should be usable in plenty of other applications with a diameter of 5 3/4". I'm sure a round rasp file would do the trick if you need to bore out the diameter a little more and a conservative cut would allow you a smaller diameter cutout with some wiggle room for filing out a perfect fit. I did a fitment check after cutting out this baffel and everything lines up great. Hope this is of some use!
http://www.technikota.com/sciontctem...007sciontc.pdf
Not Found
The requested URL /sciontctemplate/frontbaffel2005_2007sciontc.pdf was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Had to make those for my tc, I just drilled the stock speakers out, put then on top of a 3/4 inch piece of MDF, traced around, cut them out and bling I was done....takes a while put it's the only way to go...
This is the template I just used to install my fronts. Worked perfect and all the mounting holes lined up. Only thing I had to do was enlarge the opening for the speaker as my iD 6500's were slightly larger than the opening created by the template.
http://sweb.cincinnatistate.edu/mjmo...rontbaffel.pdf
DaBlackBox
134
Apr 10, 2022 02:04 PM
shaefner
Oct 8, 2003 02:48 PM
