Programming the SWI-PS
Old Aug 26, 2006 | 04:53 PM
SirPhobos1's Avatar
Default Programming the SWI-PS
I've gotten everything hooked up as it should be, but i'm having a problem with programming the interface unit. Every time I program it, the buttons don't get mapped out to where they should be.
This is what I get when I press the steering wheel buttons:
Vol Down = Band
Vol Up = Unkown, or not working
Track Down = Vol. Down
Track Up = Vol Up
Source = Mute.
I've followed the manual as it says to program. Anyone else have this problem or know what the heck is wrong here?
Old Aug 26, 2006 | 06:19 PM
IceNine's Avatar
You aren't skipping the correct sequence of buttons (by not pressing anything on your steering wheel and just pressing the programming button on the SWI-PS to skip). Those little boxes are tricky, especially if something isn't working.
Did your install require resistors? If it did, you should probably take a pic of where/how you wired them. Then I can at least give you a sanity check on that part.
Old Aug 26, 2006 | 06:23 PM
SirPhobos1's Avatar
I closed up the dash for now, cause it's driving me insane and i want to get everything else accomplished today... but i can tell you that each wire is connected with quick connect taps. the resistor is the 150 ohm resistor, which i soldered each end of to a wire, to quick connect both ends of the resistor to where it needs to go. (white interface wire, etc.)
It functions as it should, i just don't think it's programming correctly. Perhaps i'll toy with it and see if i can get a different configuration to work...
Old Sep 12, 2006 | 10:11 PM
SirPhobos1's Avatar
*Update*
I ended up exchanging the SWI-PS per PAC audio, and the new unit works flawlessly. Only had to program it once. Though, it seems a bit slower than my stock stereo was. is there a good explanation for that? Is this normal? It does not really bother me, except for when i need to press a button really fast (say, track down).
Old Sep 13, 2006 | 01:12 AM
IceNine's Avatar
It's normal, just gotta get used to it.
yupinmytC
22
Jul 27, 2024 07:08 PM
George
120
Aug 30, 2022 12:00 AM
Wrencher
May 24, 2018 10:15 AM
DryToast
Aug 4, 2015 02:59 PM
