GAH! OBX Shift knob is wiggling...
Old Sep 9, 2006 | 10:11 PM
mike6789k's Avatar
Default GAH! OBX Shift **** is wiggling...
The top part and the middle circular ring are pretty loose and they just wiggle around... how do I fix this? Is there a way to take the **** apart?
I tried taking off the hex screws on top, but that just takes off the metal cap, nothing else i think...
Old Sep 10, 2006 | 02:12 AM
bBlover's Avatar
Did u try screwing it on tighter?
Old Sep 10, 2006 | 03:53 AM
jwaggz82's Avatar
i have the same problem ....its not getting worse though ..but it wiggles. ....and I tried to screw it on tighter ...that didnt work.
Old Sep 10, 2006 | 06:55 AM
jonathan110987's Avatar
mine wiggled then i tightened the hex screws and it all tight now.
Old Sep 10, 2006 | 07:01 AM
SquallLHeart's Avatar
... the obx **** hex screws are FAKE... it's just a plastic cap...
you can remove your ****... easily remove that plastic cap by shoving a screwdriver or something into the **** and pushing it out..
and then you'll see two screws you can tighten down.
that's it.
Old Sep 10, 2006 | 07:30 AM
mike6789k's Avatar
well i took off the cap with the hex screws, and there was nothing underneath
Old Sep 10, 2006 | 07:37 AM
there's no 2 screws to tighten down that holds it all together??
well there's your problem right there.. ..
j/k.. i dunno man.. take pics...
Old Sep 10, 2006 | 05:40 PM
jwaggz82's Avatar
ya - can you take a pic since its off? im not sure if there are screws under there .... I can confirm that the hex screws ontop are indeed fake.
Old Sep 11, 2006 | 08:03 AM
Jowie's Avatar
This happened to mine too, hex screws are indeed fake. Take the *** off, take a screw driver and push the cap out. Its just press fit with a rubber o-ring. I didn't try tightening the two phillips screws in there tho. I just threw the stock *** back on... >.>
Old Sep 11, 2006 | 08:15 AM
it's those 2 screws you need to tighten if the **** is wiggling loose like the op says.
Old Sep 12, 2006 | 06:41 AM
scion_jon's Avatar
its the gasket i had to buy a bigger gasket so that the center piece would stay tight. the one that comes with the **** will snap, i learned this after 3 gaskets, have had the bigger gasket in for about 7 months no changing necessary, but i keep a lil bag of gaskets in my glove box juss incase one snaps
Old Sep 12, 2006 | 06:42 AM
scion_jon's Avatar
oh anf the allan nuts and allan wrench is included because: when u have tightined the shift **** to its most possible tightness level, and the obx is not lined up straight uyou use the allan wrench to turn the center so where you want it to be.
Old Sep 12, 2006 | 06:49 AM
........ just install the damn **** without the cap.. and then put it in afterwards.
geez people.
Old Sep 12, 2006 | 06:55 AM
scion_jon's Avatar
well said
Old Sep 12, 2006 | 06:59 AM
thank you
Old Sep 12, 2006 | 10:18 PM
jwaggz82's Avatar
which part did you buy?
Old Sep 13, 2006 | 04:50 PM
Jowie's Avatar
Gasket? What gasket? I'll have to dig mine out, but I don't remember a gasket.
Old Sep 13, 2006 | 07:59 PM
HKSpeed's Avatar
there are 2 screws under the fake hex cap. try tightening those.
Old Sep 13, 2006 | 08:37 PM
Jowie's Avatar
Oh I think you are talking about the o-ring around the center cap. Ok I get it now.
BlingSlade
Oct 19, 2016 12:39 AM
Pkdust
Oct 20, 2015 04:27 PM
user9430961
Sep 24, 2015 01:09 PM
TheGovernmenT
Sep 4, 2015 11:57 AM
Dam262a
Jul 28, 2015 03:55 AM
