Center console LCD help!
Old Oct 31, 2006 | 12:51 AM
quazentex's Avatar
Default Center console LCD help!
So I'm desoldering my center console pcb for an lcd swap and I can't get the lcd fully desoldered. It looks like there is solder on both the front and back pof the pcb. I've desoldered the back btut how do I desolder the front?
Old Oct 31, 2006 | 01:05 AM
TheQuietThings's Avatar
im pretty sure there is no solder in the front, just keep soldering the solder in the back. They will come loose, just make sure you get ALL the solder out
Old Oct 31, 2006 | 01:09 AM
SquallLHeart's Avatar
use sucker and wick.
make sure all pins loose before attempting to remove it. it should just fall out freely.
Old Oct 31, 2006 | 02:41 AM
engifineer's Avatar
Solder flows to the hottest point. When you suck or wick the solder from the back, it pulls the solder all the way through. When you are done sucking and/or wicking, you should see an empty hole where the solder was.
BlingSlade
Oct 19, 2016 12:39 AM
kb1sxv
Oct 21, 2015 05:00 PM
user9430961
Sep 24, 2015 01:09 PM
wayneside
Regional - Southeast
Sep 23, 2015 10:42 AM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
