What are relays for?
Old Nov 28, 2006 | 08:34 PM
Scionarra's Avatar
Default What are relays for?
I'm sure you guys will be more than willing to help me out on this, but I have seen several installs that would require/recommend the use of a relay (i.e. HellaHorn Supertone Horn Upgrade). It asks that you use a relay for the install. Now what exactly is a relay for? Do most installs that require it usually include it with the kit?
Thanks for the help
Old Nov 28, 2006 | 08:43 PM
nodsetse's Avatar
I thought about trying to explain them, but found something much simplier for you.
Take a moment to read this, then see if you have any additional questions.
Old Nov 28, 2006 | 08:46 PM
Neothin's Avatar
to sum it up:
they allow you to use a little switch for a big thing that draws alot of power.
Old Nov 28, 2006 | 09:31 PM
engifineer's Avatar
^^ thats it.
Lets you use a small load to control a larger one.
Old Nov 28, 2006 | 09:38 PM
SquallLHeart's Avatar
^^ to add.. make sure thingies don't go kaboom and fire
Old Nov 28, 2006 | 09:42 PM
Hyghgynx's Avatar
Default Re: What are relays for?
Not true! HellaHorn is simple plug-n-play. You don't need the relay. Instead of disconnecting the battery, I just took out the horn fuse. I was too lazy to 'reset' my tC.
Old Nov 28, 2006 | 11:39 PM
well.. sometimes the stock wiring can handle the extra load.. sometimes it can't...
better to be safe than be a screaming alpha.
Old Nov 29, 2006 | 05:38 AM
tweetertc's Avatar
dont forget theyare also used to switch polarity, make a specific resistance.. or to isolate different wiring/devices....
i love to over complicate things...
Old Nov 29, 2006 | 11:02 PM
LEDMods_net's Avatar
Strictly Scionized
^^ yes, if you need to switch polarity, use a relay. There are 4 wire and 5 wire relays. the 5 wire has a normally closed and normally open connection. That's how (for example) low beams turn off when the high beams are turned on in some cars.
SJMiller
May 26, 2021 05:18 PM
spharr62
Sep 20, 2015 01:44 AM
SJMiller
Sep 12, 2015 06:33 PM
scionsux
Sep 2, 2015 05:30 AM
Forced4
Aug 25, 2015 08:18 PM
