What are relays for?
I'm sure you guys will be more than willing to help me out on this, but I have seen several installs that would require/recommend the use of a relay (i.e. HellaHorn Supertone Horn Upgrade). It asks that you use a relay for the install. Now what exactly is a relay for? Do most installs that require it usually include it with the kit?
Thanks for the help
Thanks for the help
^^ yes, if you need to switch polarity, use a relay. There are 4 wire and 5 wire relays. the 5 wire has a normally closed and normally open connection. That's how (for example) low beams turn off when the high beams are turned on in some cars.
SJMiller
Sep 12, 2015 06:33 PM
