Weird antenna problem, recetpion funky
Old Dec 25, 2006 | 04:49 AM
EddyXP's Avatar
Default Weird antenna problem, recetpion funky
Ive had a problem with my AM/FM since i bought the car. I get reception in some areas and in some other areas i dont. Ive alread changed my stock radio to aavn5435. The stock antenna should be more than enough to get decent reception in NYC. Ive been thinking of laying down a new line of wire for the antenna, but dont even know where it runs through. Any suggestions as to how It can be fixed?
Old Dec 25, 2006 | 04:55 AM
lil_will's Avatar
ScionERA
Did you make sure to plug the antenna into the back of your new head unit?
Old Dec 25, 2006 | 04:57 AM
captainlaziness's Avatar
Deffinately solar flares. Or sunspots.
Old Dec 25, 2006 | 05:20 AM
EddyXP's Avatar
Yup, i plugged the antenna cable into the HU and made sure it was tight. Ive been having this problem since day 1 with the car. The dealer hasnt done anything as usual.
Old Dec 25, 2006 | 05:29 AM
arbnpx's Avatar
So this is with AM and FM? I had an issue where my AM reception took a nosedive when I upgraded to a Pioneer DEH-P880PRS, but it got back to where it was when they connected the remote trigger (blue wire IIRC) to the headunit. On the 06 tC schematic, that line leads to a part that says "Antenna Amplifier". I don't know if it handles both AM and FM, but from my experience, only my AM reception was cut down (I could barely pick up a 50,000 watt station whose antenna was located only 15 miles away; that's pretty bad)
Old Dec 25, 2006 | 03:55 PM
Spect2K3's Avatar
I have the same eclipse unit and the am reception is really bad. In fact, with the eclipe cd3000 which I used to have, the am reception was non-existent. With the stock radio, it was good. I never listen to am/fm though. I listen to sirius, cds, or dvds.
Being in the NY area myself, I thought there was something wrong, so I put 2 or 3 different antennas on my car which didn't help, and then even plugged in a new antenna with a wire (w/o actually running it) and that didn't help either. My antenna isn't defective. The eclipse unit just doesn't like am/fm radio I guess...i dunno, but it has plenty of features that I don't use it anyway! (btw, my fm is better than the am, but not perfect)
Old Dec 26, 2006 | 06:55 PM
IMAC_TC_NY's Avatar
I'm still using the stock hu and have the same issue with crappy reception. It is worse when I'm further out on the island by work, but not great even going through city.
Oh well, got an ipod for christmas and I'll be hardwiring it in somehow so I will just listen to the radio to find new songs to add to the ipod.
Old Jan 22, 2007 | 06:15 AM
EddyXP's Avatar
anybody know how I can lay down a new antenna line, or even better, check on the existing one? I really want to fix this problem
Old Jan 22, 2007 | 04:06 PM
Ty_Max's Avatar
I lose signal whenever big trucks get next to me...
I am so wittle
Stupid Cali Bro's and their monster trucks
Old Jan 22, 2007 | 07:29 PM
sosgal721's Avatar
You can use a multimeter to measure the resistance. It should be open curcuit between the mast and the chassis of the car. The resistance between the top and the bottom of the mast should be in the order of 0 to 20 Ohms.
If anything measures incorrectly, there is a fault in the cable or the antenna.
Old Jan 22, 2007 | 08:50 PM
deathbyc4's Avatar
neons also affect antenna reception, FYI. Didnt know if you have any or not.
djmike113
Apr 7, 2015 12:43 AM
Socialdisorder
Apr 3, 2015 01:35 AM
Kata
Mar 2, 2015 10:46 PM
missing_image
Feb 7, 2015 07:18 PM
luckypixi
Jan 28, 2015 05:29 PM
