100k service
Old Jan 4, 2007 | 02:57 PM
JustAtC's Avatar
Default 100k service
I have a tc and approaching 100K miles. I've never had any problems with this car and have never been to a dealer for any kind of recommended service. At 91000 miles, the car is still running strong and getting 30mpg so I am assuming that everything is still good. Now that it's approaching 100K mile, I suppose I will need some kind of engine service. Any recommedations...Thanks!
Old Jan 4, 2007 | 03:03 PM
jct's Avatar
jct
go with what the owners manual says to do...
Old Jan 4, 2007 | 03:05 PM
web's Avatar
web
Oil
Air filter inspection
Transmission fluid inspection/replacement (automatic: filter replacement)
Tires rotated
Chassis lube
Brake inspection
Exhaust system inspection
Underbody inspection
fluid levels
quick engine gasket inspection
motor mount inspection
serpentine belt inspection
***ask about your timing chain..........usually a 100K replacement interval with chains
Old Jan 4, 2007 | 05:11 PM
JustAtC's Avatar
i am sure they are services recommneded in the owner manual but it's not really necessary....you know what I mean....i want to know the real stuff that needs to be serviced.
Old Jan 4, 2007 | 05:17 PM
web's Avatar
web
At that point in time, stick to these areas then...
-Transmission fluid (filter/fluid if automatic and you've done normal intervals of 30K)
-bushing inspections to check for cracks or leaks
-plugs and coils (plugs are rated at around 100K so check them)
-tie rod ends
-CV joint boot inspections
-***still ask about the timing chain
-serpentine belt (normal intervals of 30K-35K miles)
-gear box (if they have some way to check it)
That should be the major areas.
captainlaziness's Avatar
100K?!? Lordy. Glad to hear that the tC holds up....not that I doubted it would....Go Toyota!
Old Jan 4, 2007 | 05:18 PM
rockbrawler884's Avatar
I'm just happy to see that someone has driven a tC over 90K Mile with no problem... It assures me that i bought the right car!
I think the dealer does have a 100K mile maintenance service package.
Old Jan 4, 2007 | 05:20 PM
web's Avatar
web
Packages are useless unless you've followed them precisely the entire life of the car. Almost everyone has had to do something that was out of the service interval schedule at one point in time so it throws it all off. It's best to keep track of what the dealer says and what you've done and come up with your own schedule according to information you find out online from reputable sources. I'm not blowing my own horn, just saying that self-saught information is the best you can find most of the time.
Old Jan 4, 2007 | 07:46 PM
SodaGuy's Avatar
100k?
Replace spark plugs with OE
Replace engine and cabin air filter if they haven't been done recently.
Drain and refill automatic transmission fluid or flush if it hasn't been done recently.
Drain and refill or flush cooling system with Toyota SLL Pink or extended-life coolant.
If you want to do an extra good job, replace the brake and power steering fluids as well.
Old Jan 4, 2007 | 10:47 PM
JustAtC's Avatar
yeah it's too reliable...it's like boring you know... but i am glad too....some of you won't believe it but here are the things/services I have done to the car since I bought it brand new from Carmax in Laurel MD. It never visited any dealers for any of those recommended 30, 60 or 90K service ever!
1) TRD spring with stock shock @ 30K and shock still holding up
2) Oil change every 5000 mile religiously using only Mobile 1 only. You can lol @ me for wasting my $$$
3) 1 set of brake pad...time for another one soon!
4) On my second set of tires
5) Occasionlly adding washer fluid...that's it!!!!
6) TRD air filter - clean it every 2 oil changes.
Best part is that it still get an avg of 29 to 30 mpg highway consistently.
Go tC........
Old Jan 4, 2007 | 10:52 PM
Boring...hey if nothing breaking is boring, I wanna be bored.
Old Jan 6, 2007 | 05:44 AM
bB2NER's Avatar
Music City Scions
I would hope that at 91K you had the tranny fluid changed a couple times and had several air filters and fuel filters changed. Oh, does the tC need valve adjustments every 40K like the xA/xB?
Old Jan 17, 2007 | 10:15 AM
TinmanTC's Avatar
Agreed.
Spending hard earned money on an un reliable car is no fun.
Old Jan 29, 2007 | 04:57 AM
jmoney's Avatar
100k? time to get anew car. haha. jk.
Old Apr 2, 2007 | 05:03 PM
bB2NER's Avatar
Music City Scions
Default Re: 100k service
So at 91K plus miles did you have your valves adjusted or checked???
Old Apr 19, 2007 | 01:35 PM
ForceNut's Avatar
I don't mean to jack this thread, but around how many miles do you need to get a new set of tires?
Old Apr 19, 2007 | 04:42 PM
bB2NER's Avatar
Music City Scions
That depends on the type of driving you do and how well you maintain your tire pressures.
yupinmytC
22
Jul 27, 2024 07:08 PM
pro710
Dec 27, 2023 03:34 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
torqueTc
Oct 8, 2015 05:39 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
