View Full Version : Clunking Noise from Rear of xB
PrincessScion
08-14-2004, 01:55 AM
I have a 2005 xB, I have noticed after the car has been parked for a while, and I start to back up, there is a clunking noise that comes from the rear end of the vehicle. This happens AFTER the car is in gear and while it is moving, it's not the transmission! It doesn't happen any other time... the rear wheels are tight... brakes?
Anyone else hear this?
Thanks!
randode
08-14-2004, 01:58 AM
is it lowered? or stock?
PrincessScion
08-14-2004, 04:08 AM
It's stock, haven't made any mods on spring or engine... just wheels... and I had the problem before we swapped wheels. Any thoughts?
Did I mention earlier that it's an automatic? If not, I just did... LOL
randode
08-14-2004, 08:03 PM
If you are standing on the drivers side of the car, look at the rear tire at about the 7:00 position. On the inside of the wheel, there is a small protrusion on the rear axle. This may be touching your tire/wheel. Check both sides.
K9_Crate
08-16-2004, 03:35 PM
OMG! My car does that too!!! It does it when I'm either backing up or when I'm pulling out of a parking space. Only when I've just started the car.
It makes a "kertunk" noise.
I read in the owner's manual that the ABS brakes, Traction Control, etc make a "noise" just after moving the car the first time after starting because they are doing a "safety check" and clicking on. I hope that this is the noise they are talking about.
My fiance's xA makes a similar noise, although much quieter.
angepac
09-24-2005, 03:00 AM
Everything is stock. I started it up and when I started to drive it clicked until the ODO passed 25MPH. When I slowed down I heard it again. It's as if something had fallen into the tire. I took the hub cap off, then the tire, then took it to the dealer, then took it to another mechanic and no one can figure out what it is. I've even rotated the tires.
Any help will be appreciated!!!
bB626
09-24-2005, 05:40 AM
my dad's '01 Avalon does that also when backing up. i believe is the brakes...
grizzly_choppers
09-24-2005, 08:13 PM
Just to clear this up a little, this was a problem from last summer, but I remember what it was.
Kristi's (PrincessScion) hubcentric rings from her wheels were not machined correctly and would not allow the wheel to fully seat against the rear drums. When transitioning from backward to forward movement the drums would rotate freely for a moment until they were stopped by the lug nut studs producing the klunk sound.
The problem was fixed when she got new hubcentric rings.
-Alex
DeansBlackBox
10-21-2005, 03:59 PM
Are you sure your not running over the neighbors cat or something to that nature....gotah look out for those little guys....
hippo
10-26-2005, 02:42 AM
holy moly i thought i was the only one, my tC sounds like that too. i heard it on the right rear before now its on the left rear. Happens also when i go like 20 mph right after i parked. Dis shyt suxs donkey nuts. i hope it is the hubcentric rings imma go to the stupid longo dealer and deal wit dis shyt.
