Need quick help - Interior lighting
Old Jan 21, 2007 | 02:24 AM
SF2K4's Avatar
Default Need quick help - Interior lighting
Ok, so when installing my short shifter a week or so ago I had to disconnect some wires to get all the console pieces out. Anyway, long story short, I have the Scion installed front lights and tapped all my lights off those lines (which I thought were cig lines but they aren't - just a white and black wire in the center console). Anyway, I thought I redid the lines but then my lights weren't working so I just assumed I'd left something disconnected. Well, I took the two ends of the white wire and hooked them up to a circuit checker and touched a ground (even flipped the switch) and it never lit up. Checked it on the battery... yup, light still works.
Did I blow a fuse? I checked and didn't see one blown not that I know which fuse would be for the interior lights.
Thanks guys.
Old Jan 21, 2007 | 02:26 AM
SquallLHeart's Avatar
the factory interior lights have their own inline fuse.
follow the wire.
Old Jan 21, 2007 | 02:52 AM
SF2K4's Avatar
Ok, I followed them back from the point I used near the shifter and from each light and I didn't see one... any idea where they generally would leave it? And I want to make sure we think it's the fuse... when I hooked it all back up the first time one LED actually worked (front left air vent) but then later that day none of it worked... where do the factory wires get the power from?
Old Jan 21, 2007 | 03:10 AM
SF2K4's Avatar
Ok, so I took the wires out of the switch and took the white POWER wire from the factory lights and simply grounded it to a point I know how to use and there was nothing... so either the inline fuse is out (but I can't find it ) or something came lose... agh.
Old May 25, 2007 | 04:14 PM
nlombardi1's Avatar
i have this same problem..so far i've check all the fuses(under hood, and drive side footwells...when i was working on replacing a cathode under one my seats... everything was fine.then i put everything back together and my lights flickered then turned off? where's the fuse for this??? is under the console?? anybody know?
Old May 25, 2007 | 04:16 PM
well... where did you wire the cathodes too?
that'd be the first question..
Old May 25, 2007 | 06:01 PM
nlombardi1's Avatar
lol.. i had the factory led interior lighting kit..swapped for cathodes..then no problems ..then yesterday i noticed one was out. replaced it with a new cathode it worked. then when i was putting on the shift console and the armrest stuff and the cupholder ..my cathodes, cup holder leds, and AC vent leds went out?? i checked the fuses nothing! so i don't know ....wut should i do??
Old May 25, 2007 | 06:31 PM
theunclesam's Avatar
^^^ Come see me mang. If you're going to J's tomorrow, I'll bring my multimeter.
Old May 25, 2007 | 07:13 PM
nlombardi1's Avatar
lol thanks dustin..i'll be there
YooItsJay
Dec 2, 2015 08:13 AM
clickclickw00t
Feb 18, 2015 08:57 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
tC6M
Nov 26, 2014 06:44 PM
sithscripter
9
Sep 26, 2003 05:27 AM
