Possible Blown Strut ?
Old Apr 20, 2007 | 04:44 PM
kanundrum's Avatar
Default Possible Blown Strut ?
SO I have TRD Shocks and Lower Springs. I autox and track my car id say very often but havent been within the past few weeks (last time was in Jan). My Right rear shock has began to rub my tire and chip off a little rubber, everytime i make a hard left(Body weight gets thrown to the right) or everytime I hit a bump on that side. I dont think its blown cause no fluid or anything is coming out but Im not too sure what else could it be
ANy suggestions ?
Old Apr 20, 2007 | 05:12 PM
kanundrum's Avatar
I could replace it just for the heck of it
Old Apr 20, 2007 | 05:56 PM
tCTaco's Avatar
Dont know..Im asuming you have at least looked under the car to make sure everything was still intact....Rear sway bar is still ok and bolted up correctly?
Old Apr 20, 2007 | 05:57 PM
Amoxaphobic's Avatar
I was under the imperssion that if it was blown, it wouldn't move in it's normal fashion. When at a stand still, the only thing really supporting your car would be the spring, so you could go and bounce on the car and see if it sways or bounces like it was on springs, you could assume that the shock was blown.
Or I could be thinking of this wrong and be really confuzled... which isn't that uncommon lately.
kanundrum's Avatar
yeap rear sway is still on and bolted good. Gonna have a looksy today well see
Old Apr 20, 2007 | 06:00 PM
kanundrum's Avatar
hmm not sure what the deal is. Im gonna go to autozone and rent some spring compressors, and then go home and check it out.
Old Apr 20, 2007 | 06:01 PM
tCTaco's Avatar
Does anyone make aftermarket end links for the Sway bar....When you set the Hotckis rear to stiff, I cant seem to get alot of threat on the bolt. Plus now with severe driving and the beefer rear sway, i would asume that the end link would become the weak point.
Old Apr 20, 2007 | 06:03 PM
kanundrum's Avatar
not to my knowledge, I know exactly what your talking about But i assume hotchkis has thougth of this and assumed it was acceptable for the way its setup. ill take some pics on how mine looks see if compares.
Old Apr 20, 2007 | 06:05 PM
tCTaco's Avatar
cool.
Old Apr 25, 2007 | 12:29 AM
StealthScion's Avatar
Default Re: Possible Blown Strut ?
ANy suggestions ?
pretty sure the TRD shocks are gas shocks, therefore, you wouldn't see any fluid leaking. what you might hear is a high pitched whistle/squeak/squeal sound as the gas is escaping from the shock. ...which is what i think i have with my TRD shocks/struts (check my thread).
Old Apr 25, 2007 | 12:42 AM
draxcaliber's Avatar
you should get in touch with otacon, he knows alot of stuff about suspension.
as for my own theory, could it be that will all the auto x'ing that your suspension has gotten softer? how long have you had the suspension on the car?
Old Apr 25, 2007 | 04:05 PM
exige's Avatar
x2
Old Apr 25, 2007 | 04:08 PM
kanundrum's Avatar
O lol Yea Joe We spent like 3 days taking off his old suspension and gettnig my bent one replaced that was fun times yea he def knows his ish, the problem went away by it self after I reseated it, think it was just improperly seated :D
kb1sxv
Oct 21, 2015 05:00 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
DannyBoy65
Sep 21, 2015 06:23 PM
OpTicaL
Sep 16, 2015 10:25 AM
goatbelly
Jul 12, 2015 10:13 AM
