Spring rate question!
Old Apr 24, 2007 | 01:43 PM
BrianGillen's Avatar
Default Spring rate question!
Spring Rate (lbs/in) Drop
Front Rear Front Rear
________________________________________________________
Stock 134 134 -0- -0-
TRD 160 150 -1.0 -1.0
Tein
S-tech 145 179 -1.7 -1.7
H-tech 129 179 -1.1 -1.1
Megan Racing 280 230 -1.85 -1.85
Tanabe
DF210 137 170 -2.0 -1.8
NF210 154 121 -1.3 -2.0
Eibach
SPORTLINE 98-206* 57-229* -2.0 -2.0
Pro-Kit 120-189* 69-211* -1.5 -1.6
Goldline 170 185 -2.0 -2.0
RS*R
Downsprings 137 141 -2.0 -1.2
I have copied and pasted this chart for ref.
I have the Megan Racing Springs....I see they have the highest spring rate available on this list.
My girlfriend complains about getting headaches whenever I have her in the car. When she drives my car though I don't get headaches but I think that is due to the fact that I've always had cars with similar setups. Oh and that I'ma totally awesome dude.
3 questions!
1) The reason for this is most likely due to the spring rates and the obviously harsher ride?
2) I will prob switch springs,...the goldlines seem like they will give me a nicer ride but still be just stiff enough...am I right?
3) Why do some setups offer lower rates in front than back while others offer higher fronts than back? What is the reasoning for this?
-Thanks
-Brian!
3)
Old Apr 24, 2007 | 09:23 PM
nobody?
Old Apr 25, 2007 | 02:04 AM
bump
Old Apr 25, 2007 | 03:46 AM
TJ's Avatar
TJ
1) You're g/f is very head sensitive. mine doesn't mind my xb with the megans. Megans are linear rate springs thus typically harsher riding. progressive rate springs will yield smoother ride since the spring rate increases as the spring becomes compressed.
2) Most reviews of the goldline are good. they make the ride smoother.
3) This i don't know the answer to. But i'm guessing to change the way the car rides. It is typical to have the front to be a higher spring rate to offset the weight bias of the front vs. rear.
Old Apr 25, 2007 | 05:10 PM
ok cool thanks you!
Old Apr 27, 2007 | 11:51 PM
jomo's Avatar
Wait a minute...linear springs with a high spring rate and a nearly 2" drop? That would mean that the springs would have to be ~3" shorter than stock. I would figure that the springs would fall out if they are linear. More likely dual rate or progressive springs.
With regard to spring rates front and rear, you have to look at the limitations of the XB suspension design. In the rear, the XB has considerably less suspension travel than the front struts. When you lower, you typically lower the rear about the same as the front. Because the rear travel is already reduced as compared to the front, the lowering makes this travel difference worse. To keep the suspension from bottoming, typically the rear spring rate for the XB is higher due to the reduced travel.
If the spring rate is very high, you don't have to worry as much about travel as the high spring rate can prevent bottoming.
Old Apr 28, 2007 | 04:17 AM
TJ's Avatar
TJ
Jomo - They may be dual rate. There is not a dead coil in the rear. but the top coil are closely spaced that the middle and bottom spots.
808xBguy
Jan 10, 2015 02:21 AM
fluxingnation
Dec 26, 2014 04:28 PM
ScionVan
11
Dec 2, 2003 09:37 PM
hydrogen
Oct 29, 2003 04:58 AM
Besk_one
Oct 16, 2003 07:45 PM
