LED dome light?
Old Apr 27, 2007 | 07:57 PM
burstaneurysm's Avatar
Default LED dome light?
Okay, so I tried to install a 4 LED dome light a few minutes ago.
It lit up and then apparently blew the dome fuse (which looks like it handles the dome light, clock, stereo and RKE). I swapped the fuse out and that stuff is working now, but is there any reason it would've blown the fuse? Both are 15V bulbs, 31MM. I can live without and LED in the dome... I'm just wondering what caused the spike.
Old Apr 27, 2007 | 08:14 PM
nerdsports's Avatar
Could be a defective bulb.
However, 15V?? You sure it's not 12V??
I installed an LED dome light this morning and it hasnt blown any fuses.
Perhaps reverse the polarity. Although it shouldnt cause the fuse to blow if it were backwards.
Old Apr 27, 2007 | 08:34 PM
It might've been 12V... I was kinda flustered when everything decided to stop working... I'm going to grab some more 15A fuses tonight after work and I'll try again. I'm wondering if it has anything to do with the fact that the incandescent does that gradual fade, whereas the LED isn't capable of that...
Old Apr 27, 2007 | 08:50 PM
nerdsports's Avatar
My LED fades. Not as smooth or as long as the incandescent bulb, but it does it.
Old Apr 27, 2007 | 09:58 PM
snowromance's Avatar
The prewired LED light you purchased was cheaply put together. Something got shorted and thats why you blew a fuse. Make sure your premade light is using the correct resistance or the next one will burn up too.
Old May 1, 2007 | 09:59 AM
bB2NER's Avatar
Music City Scions
Did you pull the fuse prior to installing the bulb?
horsefeathers
Sep 17, 2023 11:12 PM
YooItsJay
Dec 2, 2015 08:13 AM
Cadillac15
Jan 29, 2015 07:34 AM
757_BRDFLY
Jan 9, 2015 12:29 PM
TheTripleC
Jan 4, 2015 06:46 PM
