Really annoying issue with camshaft
Old 01-20-2014, 02:11 PM
DJ_FroZone's Avatar
Default Really annoying issue with camshaft
So i've been getting this CEL code P0010
Circuit bank and camshaft position actuator something ( i never wrote it down but its annoyingn.
Car runs fine, no hesitation, no leaks, just a CEL and now TSC. I live in syracuse so this not having traction is beggining to bother me.
I can reset the ecu but after the car is turned off and back on. it starts up again.
Anyone have ANY ideas on how to fix this/replace.
Mods
Header,exhaust,intake, UNICHIP
It was working fine for awhile and then just started up again when i blew a fuse in my tail lights and had to fix it.
It may be as simple as pulling a plug and reinstalling it. im all ears. Thanks
DJ_FroZone is offline
Old 01-20-2014, 04:32 PM
FIREDOG21's Avatar
Mods
First mistake... Unichip hahahah jk
maybe its the actual sensor that's gone bad?? I mean if the car is running fine...? just a shot in the dark...
FIREDOG21 is offline
Old 01-20-2014, 05:50 PM
criminaltc's Avatar
https://www.scionlife.com/forums/sho...d.php?t=187874
criminaltc is offline
Old 01-21-2014, 09:09 PM
DJ_FroZone's Avatar
BAH i love my unichip however that link does not help. Mine is a xb2. I can't find a part number or anything online
Old 01-26-2014, 03:41 AM
DJ_FroZone's Avatar
annnyyyyone?
Old 02-15-2014, 09:42 PM
oreoremix42's Avatar
In all honesty I had the EXACT same issue, took my unichip off, haven't had the problem since. Take off the unichip and reset the ECU and see if it comes back. If it does then it wasn't the unichip. If it doesn't come back on then I would assume its the unichip malfunctioning
oreoremix42 is offline
Old 02-18-2014, 03:08 AM
DJ_FroZone's Avatar
So to solve this. I just messed around for awhile. It eventually went away. no real definte fix. I had the circuit tested and it was opening fine independently. Once it went back in it would fire randomly i suppose. However now its working just fine. I had a few hour span where i had turned of TCS and it didn't like that. In the meantime i have a another one to put it in. Just incase it is the solenioid and not the chip. I've had the chip for close to 3 years now. First time i've had an issue.
Old 10-19-2014, 08:35 PM
DJ_FroZone's Avatar
So. uh. Its back again. I actually ordered another sensor. Hoping that if I swap it this team. It will be fine.
Old 10-21-2014, 07:42 PM
DJ_FroZone's Avatar
Interestingly enough it has come back on... after replacing the sensor. Pulling the unichip tonight. Running around and seeing what happens.
Old 10-22-2014, 06:39 PM
Greg S's Avatar
From what I understand with that code it's generally not the sensor that is bad but the actuator that is the problem
Greg S is offline
Old 10-22-2014, 08:06 PM
DJ_FroZone's Avatar
Any idea for a part number or anything like that?
Also i pulled the uni. So far all of the codes went away. Got a new one for a few minutes then i got a po983. Odd but so far its all good.
Old 10-22-2014, 08:25 PM
Greg S's Avatar
08 2008 Scion xB Camshaft Position Sensor - Engine Mechanical - Beck Arnley, Delphi, Genuine, Standard Motor Products, Walker - PartsGeek
Greg S is offline
Old 10-22-2014, 11:06 PM
DJ_FroZone's Avatar
I may be terribly wrong. But those are all sensors no? Though they look different from what i bought.
However
That code is gone.
My new one is po983. Which i can find no answers anywhere.
I read some cars have it being shift solenoid but nothing scion/toyota related.
If i clear it its gone. But as soon as a shift into reverse it coems on. Even in ACC mode. I wish i wasn't so OCD about CEL otherwise i'd ignore it.
Old 10-23-2014, 07:43 PM
Greg S's Avatar
However
That code is gone.
You know you're right, it is a sensor. I think I remember reading that there are two different sensors for it, but I'm not totally sure.
No idea on the new code though.
Greg S is offline
Old 04-05-2017, 07:23 PM
papdza's Avatar
I just ran into this same issue with my Unichip ! runing an K&N SRI, Tsudo Exhaust from headers, scuba delete and fireball axle back. I somehow assumed it was an issue with fuel because I have maps for high and low octane but when I turned my traction control off today all I got the CEL and had to take the unichip off. pulled the battery on the car and plugged the chip back in, cleared the codes and all is good now. I think the Unichip gets lost when traction control is touched. ITs that or the product just sucks. Anyways any recommendations on stand- alone ECU's that have harnesses that work well with Scion XB's ?
papdza is offline
Old 04-06-2017, 12:50 AM
Greg S's Avatar
Have a look at OrangeVirus Tuning, https://www.ovtuned.com/ They can remap the stock ECU for better gains than the Unichip and everything stays factory.
Greg S is offline
Old 04-07-2017, 07:33 PM
papdza's Avatar
They dont support the Scion XB anymore with tunes so looks like I either stick with unichip or go stand-alone.
papdza is offline
Old 04-10-2017, 06:39 PM
Greg S's Avatar
Well damn, that's annoying. I was going to be working with them one my built engine and supercharger.
Greg S is offline
ep3rr
03-27-2015 06:10 PM
XDC
02-01-2015 11:56 PM
eatcrispycreme2
01-30-2015 03:43 AM
eatcrispycreme2
01-30-2015 03:42 AM
eric_m
79
03-17-2013 12:21 AM
Quick Reply: Really annoying issue with camshaft
