Scion xD Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
Help with chasing a clunk?
Old 07-21-2014, 06:43 AM
BrianH's Avatar
Default Help with chasing a clunk?
Edit: I guess it took me five years to work up to my first post. :lurk:
So, I just was forced to swap my front spring coils as that's evidently something that is not uncommon to have fail in just under five years.
Work done, all buttoned up. Had to replace the endlinks on the front as one of the originals was seized to the point that pb blaster nor the torch would budge it. So, items replaced: both front coil springs (OEM), both front end links
Amazon.com: Proforged 113-10314 Sway Bar End Link: Automotive Amazon.com: Proforged 113-10314 Sway Bar End Link: Automotive
Now, I've got a clunk that I can't find. It appears to be the front passenger side. However, having taken it apart I can't find anything loose. Everything is tightened to spec. Moving everything around, I'm not able to find anything.
I'm able to produce the clunk in the following scenarios:
1.) turning left to right rather rapidly.
2.) going up a curb slowly.
Going over a bump usually wont reproduce the sound.
So it sounds like something with the swaybar or endlinks. Anyone have any tips or suggestions on chasing this?
Appreciate any feedback.
Brian
_____
BrianH is offline
Old 07-21-2014, 07:13 AM
BrianH's Avatar
Just for giggles, before going to bed I decided to loosen and re-tighten the endlinks.
aaaaand the clunk is gone. None of them felt loose when working on them. This was a problem that I didn't have after putting everything together, it worked its way out over 2-3 days. So, I'll keep an eye on it and see what it's like in a few days.
thanks for those who read this far.
BrianH is offline
Old 06-29-2019, 06:57 PM
Zed123's Avatar
Can you let us know if that helped to solve the issue?
Zed123 is offline
Old 07-03-2019, 10:44 PM
DAlex's Avatar
Since the guy hasn't posted anything in 5 years, I'd guess the answer is no....
DAlex is offline
Old 11-07-2019, 08:06 PM
BasicallyaLotus's Avatar
For those chasing clunks, here is a short list to consider...
1. Swaybar Links (OP's issue, tighten or replace) gotta use pliers or allen key to keep it from spinning to tighten!
2. Lower control arm bushings (replace LCA)
3. Motor mounts (when clunk happens with gas/clutch pedal, replace)
4. There is a service bulliten for front end clunk from the subframe. They had different bolts to fix it iirc, but i do not know if this remedy is available anymore. Torquing your subframe mounts is a good idea. Any details on this welcome.
5. Ball joints (rattle over bumps, ok when smooth, similar to endlinks, replace LCA)
6. Tie rod ends (if steering is clunky/loose, replace. There are both inner and outer for each side).
7. Wheel bearings (quite bad ones can make wheels shift and clunk, do you hear Rrrrrrrr when driving 30mph? Replace.)
8. Brake calipers or pads loose. (Rare, but I seent it. Tighten/replace)
That should cover most suspension clunks. Hope this helps someone.
BasicallyaLotus is offline
BlkTC
09-01-2009 06:39 PM
Jenna
Regional - Pacific Northwest
22
12-24-2006 02:46 AM
cadaver
07-24-2006 01:57 PM
Kijan
04-20-2006 02:19 PM
Tika
03-05-2006 12:35 AM
Quick Reply: Help with chasing a clunk?
