2004-2006.5 [NCP61]
2006 xA Factory Installed Aux Jack Repair
Old 02-20-2014, 10:48 PM
smalltimore's Avatar
Default 2006 xA Factory Installed Aux Jack Repair
Hey, ScionLife!
Been lurking for a while (Thanks for the post on replacing the side mirror. Stupid baltimore drivers.), but now I have a question I have not been able to search my way to enlightenment for.
My aux jack has recently been shorting out during use. I lose the entire left channel and no amount of wiggling the cable or holding in a certain position will help. Yes, I also tried a brand-new mini-jack cable. This brings back childhood trauma of bad experiences with off-brand Walkmen.
I was hoping I could just get access to the jack and re-solder the contacts or replace it, but I have no idea how to remove the housing around it. I was thinking of subscribing to Chilton's for a month to see if they had instructions, but I am a cheap bastard that believes strongly in the Wisdom of the Forum.
Thanks in advance for any guidance.
- Alan
smalltimore is offline
Old 02-21-2014, 08:52 AM
jct
jct's Avatar
you have to remove the center console to get to it... remove the shift **** and there is a screw in the back cup holder and the front is held on with clips...
jct is offline
Old 02-21-2014, 01:40 PM
Thanks for the reply! I did see that screw in the rear cup holder. So if I remove that, I assume the center console will then lift from the back to the front which will disengage the clips or something like that? This doesn't sound too bad...
Old 02-21-2014, 06:56 PM
jct
jct's Avatar
pull up at the front to disengage the clips... and remove the the cover right under the parking brake
jct is offline
wiltonhall
01-28-2015 03:46 PM
RichBinAZ
12-21-2014 12:05 PM
Kiwibox
12-15-2014 09:46 PM
minter66
12-15-2014 01:45 PM
TheRedBox
31
12-02-2003 04:53 PM
Quick Reply: 2006 xA Factory Installed Aux Jack Repair
