Sunroof noise...not really a rattle
Old Sep 7, 2007 | 02:18 PM
KingPadmei's Avatar
Default Sunroof noise...not really a rattle
This may be another post, but I couldn't find it. I have an '07 mostly stock tC. I just recently started getting a noise from my sunroof that is very aggravating. It sounds like the car is creaking and cracking when I turn, or go over a bump, kinda like you'd hear on a sailboat. Funny thing is, or rather depressing thing is, it only happens when the sunroof is in tilt mode. If the sunroof is closed, or when it is slid back it doesn't make any noise. But I like to tilt my sunroof. I suspect it has something to do with when I installed my sub, and the windows reset because I unplugged my battery, and I put the sunroof back and I think it may have gone farther than its supposed to before I figured out what was happening. It didn't make a noise RIGHT after that happened, but I'm trying to think of anything I may have done. Any ideas?
Old Sep 7, 2007 | 04:23 PM
DjEzE's Avatar
when you push the botton to open automatically, when it stops push it again. it need to go back another like an inch or two. see if that works.
Old Sep 7, 2007 | 04:24 PM
CDogbert's Avatar
Mine did the same thing, and the dealer said there's a bulletin on the sunroof. Take it to your dealer.
Old Sep 7, 2007 | 05:20 PM
KingPadmei's Avatar
Im going in anyway next week, so Ill ask them if they can fix that too, thanks for the answers, sorry if its a repeat.
Old Sep 7, 2007 | 05:58 PM
tattooboyzgirl's Avatar
I had the exact same problem with mine, its a 2007 also and when I push the button the first time and it goes back halfway it will creak so I always push it all the way back. I am so sick of taking this car to the dealer I am just giving up and letting it be!
Old Sep 7, 2007 | 06:12 PM
KingPadmei's Avatar
Its only when it is tilted, not opened. Like when it is fully close you hold it and it tilts up, then goes all the way back, up it only does it when it first tilts up. If open the sunroof it goes away, no matter how far its open
Old Sep 7, 2007 | 07:31 PM
CDogbert's Avatar
Be warned that your dealer is going to need your car about half a day to replace the sunroof.
Old Sep 8, 2007 | 06:39 AM
iggy373's Avatar
does anyone know the TSB # for this one? I have the same problem, only my dealership couldn't hear it, surprise. I only notice it when the roof is in tilt mode as well.
Old Sep 8, 2007 | 07:33 AM
CDogbert's Avatar
I couldn't find one, but it requires that the entire sunroof cover cartridge be replaced, if I heard right.
Old Sep 8, 2007 | 10:41 PM
Resu's Avatar
Default Re: Sunroof noise...not really a rattle
Take it to the dealer. I had the exact same thing happen. Got mine back and no more creaking. I'm not sure if there was a recall on this issue for toyota, but I know that they have the solution. I know they put tape somewhere in there, you can actaully see where they put it but I can't give you the exact part that they put it on. Sorry if I'm late on this and you've already gotten things fixed.
Old Jun 11, 2008 | 10:42 PM
tc88's Avatar
Sorry for bringing this old thread back, but I was wondering if there are any updates on this? I have an 06 and have this issue also. I brought it in to the dealership a few months ago and they lubed the tracks, but that actually made it worse. Now, it's still there and I'm wondering what to and if there were any TSBs out there for this issue on the 06s. Thanks for any help in advance.
Old Jun 12, 2008 | 01:14 AM
tcleazy-girl's Avatar
I'd try initializing the sunroof motor position first. It's pretty simple too.
Old Jun 12, 2008 | 01:15 AM
momstc's Avatar
mine does that too
Old Jun 12, 2008 | 04:58 AM
KingPadmei's Avatar
I have not fixed it. I live in Maine and my sunroof has been closed for the past....6 months...
Old Jun 12, 2008 | 02:15 PM
CDogbert's Avatar
Do that. If that doesn't fix it, take it to a different stealership.
Old Jun 15, 2008 | 11:10 AM
tc88's Avatar
I tried searching, but I can't find anything about how to do this. Could you tell me how to initialize the sunroof motor position?
Old Jun 15, 2008 | 03:37 PM
drjohnson36's Avatar
1. Turn the ignition key to ON
2. Press the moonroof switch to the CLOSE side until the moonroof is fully closed
3. Keep the switch depressed for at least 2 seconds after the moonroof is fully closed, this is so the ECU can recognize the "closed" position
4. To acknowledge that the programming is complete, the moonroof should open itself up a little bit
Source: http://home.cfl.rr.com/icdedppl/faq.html#c14 - The TC FAQ site
Old Jun 25, 2008 | 02:55 AM
tc88's Avatar
Thanks for that link, drjohnson36. However, it did not solve the problem. If anyone else has any input, it'd be much appreciated.
Old Jun 25, 2008 | 12:35 PM
sciondrgn's Avatar
My 07 makes a popping sound, to me it sounds like its coming from the back piece of glass on the roof and usually only happens when taking angled or curves turns, like going in a driveway or something
Old Jun 25, 2008 | 12:45 PM
TheFantasticG's Avatar
[quote="drjohnson36"][quote="tc88"]
First time I did that, I didn't know I did it.
Freaked me the fark out. Moonroof just opened by itself.
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
Prolific998
Scion tC 1G ICE & Interior
Apr 16, 2017 06:09 PM
BlingSlade
Oct 19, 2016 12:39 AM
SFXB
Jul 9, 2015 11:00 PM
