need help...tail light installation
Old Oct 22, 2004 | 02:31 AM
Kong's Avatar
Default need help...tail light installation
I know that it sound crazy. But I'm having problem installing tail lights. There is two 10mm nuts to be removed on each side. I successfully install the right tail light, but I couldn't remove the top nut on the left tail light. It is in the blind spot that I can see and is hard to get to it. It is so tight that my wrench couldn't get it out. I tried for about half an hour and the nut is rounded out in all cornors (still have some flat area, but no more sharp cornors) . I went to Kmart to get a Gator grid wrench. It can't remove the nut either
I will post a picture of my box with one stock and one TYC taillight tomorrow. It looks weird...
Anyone have any good idea of how to remove the broken nut?
Thanks!
Old Oct 22, 2004 | 02:36 AM
Da_BoX's Avatar
Not quite sure, but try doing a search.
Old Oct 22, 2004 | 02:54 AM
Kong's Avatar
I did a search. And I found some useful stuff.
Nut splitters
http://amos.shop.com/amos/cc/main/ca...t-Splitter-Set
or a taping kit at home depot
I will give it a try tomorrow.
Old Oct 22, 2004 | 03:06 AM
Kong's Avatar
I found some more cool stuff and would like to share..
1. Heat the bolt only first, then let it cool naturally.
2. Heat the area around the bolt AND the bolt at the same time.
3. While the bolt and surrounding area are hot, get an ice cube and put on the bolt ONLY.
4. Normally, if you can get a pair of vice-grips on the bolt, it will spin right out. No drilling required.
hope this applies to removing nuts also.
Old Oct 22, 2004 | 03:49 AM
Dewmerz's Avatar
try something like this. I have never used them but that is what they are for. http://www.sears.com/sr/javasr/produ...52161000&cs=e5
Old Oct 22, 2004 | 03:59 AM
wgeee7478's Avatar
Actually I used a set of these and they work wonders.
Old Oct 22, 2004 | 12:10 PM
Kong's Avatar
Thanks a lot!, I will try it today. I hope it works
Old Oct 23, 2004 | 01:41 AM
Kong's Avatar
an update.
I went to sear to get stripped nut removers. I tried it, but it doesn't work. Can't get enough grip to untight it and now, the nut is totally rounded off. I have a mechanic helped me and he couldn't get it out either. So the solution for now is to remove the whole panel round the tail light and use a visor grip to untight it, or may be break it. This sucks real bad!! This nut really makes me nut
Anyone has a less destrutive idea?
Old Oct 23, 2004 | 09:23 PM
Kong's Avatar
Ok, today I retried to remove the nut using the craftman stripped nut remover. It actually works. Now I have new taillight . Thanks a lot guys!
Old Oct 23, 2004 | 09:29 PM
TheScionicMan's Avatar
Perseverance pays off!
Now wheres the pics?
Old Oct 23, 2004 | 09:53 PM
Kong's Avatar
Here it is ..
https://www.scionlife.com/gallery/sh....php?photo=772
BTW how do I add photo to the reply?
Old Oct 23, 2004 | 10:04 PM
Originally Posted by Kong
Here it is ..
Take the actual address of the photo(right click on image:
https://www.scionlife.com/gallery/da...BackXB-med.jpg
Paste that into your post, highlight the whole string and hit the Img button on the top. It will add the bracketing needed and you end up with this:
Also, click on Quote for this post and you can see the formatting in plain text...
xBSciontist
Jun 18, 2019 03:06 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
tc_Jake
Dec 31, 2014 01:45 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
