air bag light blinking
Old Nov 1, 2004 | 05:28 AM
turtles808's Avatar
Default air bag light blinking
My air bag light just started blinking. I was told by the dealer that next available appointment would be end of the month and not to worry. They said that is shouldn't just inflate even though they never looked at it and don't know exactly what's wrong with it yet.
Is this a common thing? Has this happened to anyone else yet?
Can any Scion service people offer some insight to this problem. Is it a major or minor problem?
Old Nov 1, 2004 | 05:38 AM
squirrel's Avatar
Did you change out your driver seat?
Old Nov 2, 2004 | 04:18 AM
turtles808's Avatar
no, but i did through some junk under there the other day.
does the wire run under the seat?
Old Nov 3, 2004 | 02:25 AM
tCtech's Avatar
the under seat should be irrelevant. look to see if you did unclip something anyway.
the air bag won't go off. and a month wait for an appointment **Bleep**.
complain to service managers, or higher. that is a safety device. it's an important thing. if you crash before "an available appointment" and it doesn't deploy....
yeh, _____ at people and get that handled asap
**Edit - Language**
Old Nov 3, 2004 | 03:06 AM
Max2k's Avatar
Did you unbolt it or disconnect it?
Old Nov 4, 2004 | 04:58 AM
turtles808's Avatar
no, i didn't do anything but throw some stuff under the seat. when i unplug the wires from under the seat, the light stays and doesn't blink so it must be something malfunctioning. i'll call the service people again and see if i can get an earlier appointment.
thanks for the suggestions.
Old Nov 4, 2004 | 09:34 PM
Minsk99's Avatar
There is a connection for the airbag circuit under the drivers seat. It has a quick release connection so that the seat can be removed. Perhaps when you put something under the seat you disconnected or loosened it. The connection is about 6 to 8 inches back from the front of the seat on the far left under-side (from seated drivers perspective). The connection is made by two white plastic pieces that snap together. Make sure they are snapped together all the way. You might need to reset the ECU after you do this to get the airbag code cleared out. To do this either disconnect the battery for a few minutes or recently a FAQ was just added about how to do this without disconnecting the battery (check in that section).
Old Nov 5, 2004 | 01:09 AM
squirrel's Avatar
When you disconnected the plugs, and reconnected them, did it still blink? I would do what Minsk99 suggested and reset everything by disconnecting the battery.
Old Nov 5, 2004 | 04:21 AM
Back_In_Black_xA's Avatar
In the steering wheel there is a thing called the spiral cable which allows you to turn the steering wheel and still have electrical connections on the steering wheel (air bag and horn). See if your horn works or not. If it doesn't its probably the spiral cable. I had that problem on a Camry the other day.
carid
Jan 22, 2015 12:49 PM
toyotaisme
Jan 10, 2015 10:24 PM
Beesh
Jan 9, 2015 06:30 PM
LinexA
Nov 21, 2003 02:54 PM
GreatWhitexA
12
Nov 19, 2003 04:32 PM
