Swapping Single CD for 6 CD
Old Nov 7, 2004 | 03:02 AM
Submerge's Avatar
Default Swapping Single CD for 6 CD
Greetings,
How difficult is it to swap a 6CD for a singe CD radio in an XB? My new xB came with a singe and my wife does not use the 6 CD changer in the xA.
Thanks,
Dave
Old Nov 7, 2004 | 03:28 AM
BoomBox757's Avatar
DelMarVa
pop the center dash off, unscrew the cd player, un hook it. do the same to the other car then, plug it in, screw it in, and put the dash back on., should take no more that 30 min
Old Nov 7, 2004 | 03:34 AM
BabelBox's Avatar
It's very easy. I can't find the exact topic to replace the head unit. But you can check this postt.
https://www.scionlife.com/forums/viewtopic.php?t=23214
Old Nov 7, 2004 | 04:33 AM
RogueXB's Avatar
Don't you need a security code to reset them??
Thats whay I heard.
Old Nov 7, 2004 | 01:49 PM
BabelBox's Avatar
No security code. I bought my 6-disc head unit from another member here. It was a brand. It's easy as Plug and Play.
Old Nov 7, 2004 | 04:44 PM
Submerge's Avatar
Would appreciate a few more details on how to get the center dash off. Last thing I want to hear when pulling is SNAP! and then see small plastic parts flying around the interior!
Thanks,
Dave
Old Nov 7, 2004 | 06:07 PM
BoomBox757's Avatar
DelMarVa
Thanks,
Dave
pull the ac ***** off and there are 2 screws, one behind the right and one behind the left, unscrew them and then push down on the top(right above the cd player) and pull out at the same time. its a little nerve reacking, just push down and pull. and if it doesn't come off your now pulling hard enough
Old Nov 9, 2004 | 09:03 PM
rad401k's Avatar
if you run into what i did getting the center piece back on is the tricky part for some reason
Old Nov 9, 2004 | 10:09 PM
BoomBox757's Avatar
DelMarVa
put the bottom on first and walk your way up, or start at the top and work your way down, should be s sinch
Old Nov 9, 2004 | 11:31 PM
Max2k's Avatar
It's easy to take the dash off the xB, it only takes me about a minute now that I'm used to it.
Just pull the ***** off, undo the 2 screws, grasp the console firmly by the A/C ducts, and pull straight out. You'll get about 2 inches of play before you have to unplug the 3 wire harnesses.
Old Nov 10, 2004 | 01:11 AM
BoomBox757's Avatar
DelMarVa
ohh yea once its popped off stop pulling and undo the harnesses
oops if you kept pulling that wouldn't be good at all
yupinmytC
22
Jul 27, 2024 07:08 PM
oldcodger
Scion tC 1G ICE & Interior
Dec 24, 2015 09:46 PM
BlingSlade
Sep 5, 2015 08:52 AM
TheGovernmenT
Sep 4, 2015 11:57 AM
StxArOne
Jul 13, 2015 06:25 PM
