AVIC D3 owners! or anyone.
When you installed the head unit. Did you ever spliced anything with the brake line so it would play movies while driving?
I thought it was just a pin removed from the harness... The little connector things?
My ebrake light just started turning on when I accel hard. Anything?
just take the mute wire and the brake wire and splice it to the huge grounding wire U that is on the harness. Then move the mute wire up a hole. That is what I did, You'll be good to go.
it's already installed.... grrr.... oh well.
so the ebrake line never got spliced...? and there is just a ground running to the one pin in the harness? that's it right?
uh if you are saying you spliced into your actual ebrake wire........yea thats a no go.
very simple. 1) move mute wire 2) ground mute wire 3) ground ebrake wire FROM HARNESS. (not comin out of your car)
so in other words, all the splicing/modifying is done through the two harnesses that come with the d3 unit and plug into its back.
PostRelease
Oct 26, 2009 04:59 PM
PostRelease
Scion tC 1G ICE & Interior
PostRelease
