UPDATE: CAI "Check Engine" light
Old Nov 16, 2004 | 07:51 PM
gojann's Avatar
Default UPDATE: CAI "Check Engine" light
hi there.. I'm the one having problem after installing an Injen cold-air filter.. i'm here @ my uncle's shop, they have a code reader here for Scion/Toyota.. there's a code that says "air sensor voltage high" .. does it means the air mass sensor is broken? can somebody knew what's going on? the check engine light is on, and the RPM of the car is limited to 2900.. thanks..
Old Nov 16, 2004 | 07:59 PM
G-NIZZLE's Avatar
WHAT IS THE CODE NUMBER ???
Old Nov 16, 2004 | 08:03 PM
squirrel's Avatar
Is the air sensor mounted correctly? Is it dirty? Have you tried unplugging either the fuse or the negative terminal? If you were closer to Tracy, I could check it out for you.
Old Nov 16, 2004 | 09:04 PM
ScionSniper's Avatar
Make sure that air sensor isn't damaged also!!!
Old Nov 16, 2004 | 11:13 PM
squirrel's Avatar
If anything, its prolly what Tim posted. ^^^^^^^^^^^^^^^
Old Nov 16, 2004 | 11:39 PM
mikochu's Avatar
moooved!
Your MAF might be messed up. Did you make sure it was securely fastened on the intake? Take it off and make sure it's clean...
Old Nov 16, 2004 | 11:41 PM
Ditto!! Mikochu you beat me to it!!
Old Nov 17, 2004 | 12:08 AM
mikochu's Avatar
*bang bang* ;)
Also, make sure the MAF is securely plugged in... Unplug it and plug it back in if you have to...
Old Nov 17, 2004 | 01:14 AM
gojann's Avatar
i went to toyota dealership today.. they say that the AIR FLOW SENSOR is broken.. they will order the parts today, and it's gonna be ready this THURSDAY.. so, is it advisable to put the CAI again? what do you think???
What is MAF mikochu???
thanks..
Old Nov 17, 2004 | 01:15 AM
mikochu's Avatar
A MAF is the air sensor. Mass Air Flow sensor...but yeah, just be careful with putting it on the CAI...
Old Nov 17, 2004 | 04:27 PM
squirrel's Avatar
Just becareful re-installing it.
Old Nov 18, 2004 | 05:06 AM
Big_Jim's Avatar
i've been reading tons of problems with the injen intake. seems like no one is having problems with the aem or the typoon intakes.
any other input?
Old Nov 18, 2004 | 06:32 AM
mikochu's Avatar
I think the people who were having problems with the Injen intake were the ones who had the xB only CAI...
Old Nov 18, 2004 | 02:28 PM
hongs66's Avatar
I've got the Injen XB cai and it's been on for over 15K miles with no problems. Just drove up to Tahoe last weekend and got over 30 mpg for over 900 miles.
Old Nov 18, 2004 | 08:03 PM
Minsk99's Avatar
I'd try cleaning the MAF sensor before buying a new one. I used QD Electronic Cleaner made by CRC. Make sure that you get the kind that is for "Sensitive Electronic Equipment". You can get a can at any automotive store or Home Depot. Also, don't get the kind that says for Automotive, it should say "QD" on it. Spray it all over the sensors of the MAF and let it self dry for a few minutes. It works very well. Also, like a few already mentioned, disconnect the battery for a few minutes after cleaning and reinstalling. BTW, what is the dealership asking for a new MAF?
Old Dec 22, 2004 | 01:23 AM
erichlf's Avatar
I have a question about the engine light coming on due to MAF getting dirty. The mechanic at Scion said that due to higher airflow rates it gets dirty and this causes the light to come on. He also said that it was going to keep doing this and would eventually get worse. I have a K&N Typhoon any suggestions to solve this problem?
Old Dec 30, 2004 | 07:49 AM
blacvios's Avatar
Could this be caused by oil depositing on your sensor from the knn filter, if over oiling the filter will results in it being deposited onto the maf sensor, try getting a IPA alcohol spray cleaner and spray it clean.
Old Dec 30, 2004 | 08:01 AM
KYBoy's Avatar
Scion Corps
DeepSouth Scions
I have the Injen on my 03 corolla and it has been great. It makes a nice sound when i give it gas, and nice increase of 11 hp. Call Injen and tell them what happened, they might pay for your MAF
Old Dec 31, 2004 | 11:27 AM
k4kas's Avatar
DeepSouth Scions
In my Focus mass people had this problem.
The overoiled filter was letting the oil get onto the MAF wire.
Causing a CEL.
You can also safely use Non Chlorinated brake cleaner to clean it.
It will be plainly marked as such.
xBSciontist
Jun 18, 2019 03:06 PM
hampton1100
May 28, 2015 07:32 AM
AdmirN
Jan 5, 2015 10:19 PM
Strader
25
Jul 22, 2004 09:27 PM
Docsnuff
9
Nov 23, 2003 09:50 PM
