Running electrical from engine compartment to inside
Old Nov 25, 2004 | 04:24 PM
shrktank's Avatar
Default Running electrical from engine compartment to inside
I am looking to adding some LED lights to brighten up the cup holder area. I wantt o run off the headlight fuse so the LED's only come on when I need light. Can some one tell me the best way to run the wire from the engine area to the inside of the vehicle.
Old Nov 25, 2004 | 04:28 PM
dgHotLava's Avatar
why do you need to run a wire from the engine compartment inside to do this???
all the wires are inside for this mod.
run the wire from the headlight switch (wires are in the steering column).
Old Nov 25, 2004 | 04:41 PM
shrktank's Avatar
Dg: How will I know which wires are the headlight ones and do I just splice into them? I am a rookie moder and new messing with electrical
Old Nov 25, 2004 | 06:16 PM
dgHotLava's Avatar
an easier way to get this done is like the RS1.0 style (or the randode kit)
tap the power off of the cig. lighter. put a switch on one side.
that way you could turn them on and off any time the car is on (not on and off with the headlights)
(do you have a test light or multi meter?)
Old Nov 25, 2004 | 07:57 PM
shrktank's Avatar
That sounds simpler. I do not have a test meter . As far as a switch where can I get one that would look factory installed? I notcied there is slots for what appears to be 3 or 4 switches on te center console. Are those standard size
Old Nov 25, 2004 | 09:41 PM
dgHotLava's Avatar
don't know about a factory switch. try a pepboy or autozone place...
or you could get a switch from toyota (like the foglight switch)
i suggest you get a test light or multimeter. so you can test for positive and negative wires.
Old Nov 25, 2004 | 11:07 PM
superfreestyle's Avatar
DeepSouth Scions
Default Switch
https://www.scionlife.com/forums/viewtopic.php?t=29672
There is a switch for ya
Old Nov 26, 2004 | 12:53 AM
black_xb's Avatar
radio shack has the identical switch as the foglight switch for 3.50 thats what i used for some cooling fans for my stealth installed amplifier..
Old Nov 26, 2004 | 12:57 AM
dgHotLava's Avatar
good calls ^^^
Old Nov 26, 2004 | 01:43 AM
TheScionicMan's Avatar
for my cupholder lights, I tapped into the lights for the shift indicator light. (This is for Autos only) Was easy to wire, but I wish they were switchable like the rest...
Old Nov 26, 2004 | 01:57 AM
Max2k's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=29238
This should help you.
Old Nov 26, 2004 | 05:33 AM
ikhonlord's Avatar
You can use that link or here is another "Old School" link..
https://www.scionlife.com/forums/viewtopic.php?p=16569
:D
I like the first one because it has nice pics and the second one because if you have no clue how to wire the switch or how you should connect ure cathodes this post has a nice wire diagram in the middle of the page...
Hope all of this helps....
Old Nov 27, 2004 | 02:01 AM
erichlf's Avatar
Default gasket
there is a gasket on the driver's side above the break pedal with a whole bunch of wires coming out of it. Send it through that.
Old Nov 27, 2004 | 03:35 AM
shrktank's Avatar
Thanks for all the great information. Plan on doing this minor project tomorrow
missing_image
Feb 7, 2015 07:18 PM
Ramroids55
Jan 16, 2015 02:42 PM
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
eric_m
29
Oct 12, 2003 08:22 AM
