No sound
Old Apr 27, 2008 | 05:27 PM
stevejohns29's Avatar
Default No sound
so i was wiring in a new amp into the stock headunit. Everything was working fine. i turned on the radio to make sure it was working well before i taped everything. I was just finishing taping and the bass hit pretty hard and then there was no sound.. at all..
I unhooked the amp completly out of the stock wiring harness to see if it was just the amp but there is no sound at all. The headunit turns on and everything but thats it? Any ideas what happened? Maybe its a fuse or something?
Old Apr 28, 2008 | 06:20 PM
jurassic1's Avatar
You did disconnect the batt before starting to install the amp right? And did you install a separate fuse for the Amp's power wire?
Hopefully you've just blown a fuse somewhere. Check all fuses (I'm not sure if the stock HU has a fuse located at its back side).
Or, your speakers maybe blown (???). I don't know how else to confirm it other than connecting another speaker to the existing speaker wires and see if any sound is produced. Good luck!
AMS13
Aug 28, 2015 07:05 PM
6885BLM8435
Aug 19, 2015 03:08 PM
excessads
Aug 19, 2015 02:37 PM
Suburban
Aug 17, 2015 01:22 AM
iFangy
Aug 13, 2015 05:10 AM
