Anyone else have a slipping clutch?
Old Dec 1, 2004 | 10:24 PM
FModFTD's Avatar
Default Anyone else have a slipping clutch?
Here's the details:
'05 xA, 5 speed, 7500 mostly highway miles, totally stock. At about 65 mph and full throttle in 5th gear, the rpms go up a few hundred and then back down. It happens mostly in cold weather (~40 deg. F). It might be happening in other gears, but it's hard to tell.
Anybody else experience this?
Is there any way to test/prove this besides using a dyno?
Plus, is there an adjustment on the clutch? The clutch engages a bit high off the floorboard. I noticed the clutch fluid shares the brake fluid reservoir. Would this mean air bubbles formed in the brake lines could get into the clutch line?
I'm gonna get the manual online and investigate further.
Old Dec 2, 2004 | 01:55 AM
scionxb04's Avatar
its why i upgraded to the trd clutch....now that the stock clutch is gone i can tell u it sliped a lot
Old Dec 2, 2004 | 02:11 AM
dgHotLava's Avatar
mines not gone yet, but i bet it will go in the near future...
trd clutch and LSD here i come...
Old Dec 2, 2004 | 03:09 AM
too_boxy's Avatar
waiting for mine to go out. Plan on putting fidansa flywheel and trd clutch.
Old Dec 2, 2004 | 04:14 AM
SWF_05_tC's Avatar
Uhh.. how many miles do you people have? If you're replacing clutches with low mileage on them, then I'm going to get my ___ in gear and do the 2ZZ and celica tranny swap ASAP.
Old Dec 2, 2004 | 07:06 AM
scionxb04's Avatar
do what i did...just have the stock one backcut....much cheaper.....
Old Dec 2, 2004 | 08:58 AM
eh... i'd get a lightened one. a backcut can sometimes weaken the flywheel massively. depending on the application. i've heard horror stories. i've had my clutch slip a lil bit too.(4800 miles) not too often tho or too bad. wanna do the trd. but wanna do the 2zz so dunno if it's worth the trd. but if i ever sold the motor the trd could help sell it.
Old Jun 7, 2005 | 07:32 PM
JMD83's Avatar
What is this engine/tranny swap all about...? Is this tranny you speak of a 6 speed? Can it be mated to the stock xA/xB motor?
Do tell...
Old Jun 7, 2005 | 09:54 PM
the tranny's are not interchangeable between zz motores and 1nzfe's . the 6spd from a 2zz will fit the 1zz and the 5spd from a 1zz will fit a 2zz. the 6spd tranny is huge and would require massive cutting to fit.
Old Jun 7, 2005 | 11:48 PM
JMD83's Avatar
Darn...
WRX1316_TcVicent
Jul 22, 2021 06:06 PM
a23r
Feb 1, 2016 04:05 AM
carbinefreak
Sep 24, 2015 02:06 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
scionsux
Sep 2, 2015 05:30 AM
