Front LED Turn signal bulbs
Old Oct 29, 2008 | 08:25 PM
chizwiz's Avatar
Default Front LED Turn signal bulbs
I tried search and well i did not completely find anything
is there anyone that changed out their front turn signal bulbs and put in LED bulbs?
Old Oct 29, 2008 | 08:29 PM
user 7208230's Avatar
I have them on my SW tC but I don't have pictures right now. superbrightleds.com is where I got mine, you will need a resistor so they flash at normal speed, i love mine.
Old Oct 30, 2008 | 01:41 AM
miketf1's Avatar
the bulb is 1157 its a dual circuit bulb. you need a load equalizer or a new flasher to make it flash normal speed
Old Oct 30, 2008 | 06:15 AM
Kind of like these, at least this is what I used since I wasn't sure which flasher I needed. Works fine:
[urlhttp://superbrightleds.com/pdfs/load_resistor_info.pdf[/url]
Old Oct 30, 2008 | 11:30 AM
chizwiz's Avatar
Thanks for the info, will look into it and post pics when i finish.
Old Oct 31, 2008 | 03:07 AM
chizwiz's Avatar
I believe this is what I want;
http://superbrightleds.com/specs/115x-x12x19.htm
but not sure between the narrow or wide and should I use the flasher module or the load resistor?
Old Oct 31, 2008 | 05:30 AM
more is always better w/ LED bulbs. Isn't the bulb in the xB2 face straight ahead? If so, i would say the 19, as for the resistors, i have the load resistors and it works great just tap into the wires and you're done. Good luck, i'll try and take pictures of mine so you can see.
Old Oct 31, 2008 | 09:28 PM
rockthebeef's Avatar
I read that LEDs are not safe when they're in the same housing as the headlights because they don't tolerate heat very well. Can somebody confirm this?
I would really like to try these out. They are white until you use the turn signals, then they are amber. Sweet!
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Old Oct 31, 2008 | 11:57 PM
CIONIDE's Avatar
Same concept, different company, with more options. Available with several different bases, 20, 30 and 48 LED versions, and two different bulb diameters for the 7443 base. Our stock front turn signal is a 1" diameter 1157 bulb, so these will work fine.
http://autolumination.com/switchback.html
Old Nov 1, 2008 | 06:41 PM
miketf1's Avatar
i have the switchback and its pretty cool. and yes heat affects the life.. about 5LEDs have burned out on the switchback..
Old Nov 3, 2008 | 12:51 PM
chizwiz's Avatar
Still decideing on what I wanna do, will post when I decide.
xBSciontist
Jun 18, 2019 03:06 PM
randomsuper
20
Jun 13, 2015 10:56 AM
mischman
Jan 14, 2015 06:07 PM
minter66
Dec 15, 2014 01:45 PM
Opr8r
20
Feb 25, 2004 11:29 PM
