vvt-i
Old Feb 22, 2005 | 11:13 PM
ljljaylj's Avatar
Default vvt-i
does anyone kno how when or where to get ur vvt-i adjusted...cuz my friend juss blew his celica gts after smoking GSR's and RSX's....i heard ur spose to adjust it every certain miles but how?
Old Feb 23, 2005 | 04:44 AM
UnFocused's Avatar
Your friend is on crack!
Your valves are adjustable, but VVT-I is all electronic (hense the intelligence part)
Old Feb 23, 2005 | 05:30 PM
Cockpit_XB's Avatar
Admin Emeritus
from what i heard there's really no way of adjusting it, i know you can get rid of it but dont know about adjusting it like v-tec. You might want to try hitting up like autolink motorsports, signal auto, or maybe titan motorsports. Hope this helps your friend out.
Old Feb 23, 2005 | 05:53 PM
kacosta's Avatar
if its a gts celica your freind has bent valves and possibly a hole in the piston the valve adjustment you speak of is done
with special tools and training the parts to be replaced are shims that come in differnt sizes usualy this is not a regular maint item adjustment is done during cyl head repair if its the gts the adjustment is even more complicated than the regular engine i hope your freind did not damage his engine
i usualy repair them after someone misses a shift or over revs the engine this in many cases bends the valves and or damages the pistons the vvti is just the system that advances your cam gear via electronics and directed oil pressure
Old Feb 23, 2005 | 06:32 PM
TheKnown's Avatar
yea what he said
Old Feb 23, 2005 | 07:02 PM
TimmyT's Avatar
Scion Society
also. are you sure he doesn't have vvtl-i? Thats toyo's version of v-tec. and what they mean when they ask if the car has "lift" or when they state "When it hits lift.". In that case. I've heard of people adjusting when v-tec or vvtl engages, but also heard its not really recommended either.
Old Feb 23, 2005 | 07:20 PM
Minsk99's Avatar
Not sure if this is the type of "adjustment" you are talking about, but Power Enterprises is coming out with a cam timing controller for the vvti in a few months.
Old Feb 23, 2005 | 07:26 PM
unlmtdndeavor's Avatar
there is no need to adjust your vvt-i engagement point periodically. it is set in your ecu when to engage. the power enterprises one coming out is going to be used to tune the motor to respond at specific power bands...helpful for FI engines and even N/A ones if you decided to get new cams. it is equivalent i believe to the apexi super vtec afc.
Old Feb 23, 2005 | 07:33 PM
TimmyT's Avatar
Scion Society
vvt-i is nothing like v-tec. yes both involve valves. but vvt-i doesn't have the performance lobe like a v-tec has. vvtl-i does. check this out for more information.
http://www.toyota-europe.com/technol...es/vvtl_i.html
Old Feb 24, 2005 | 02:25 AM
its_ikon's Avatar
celica doesn't have vvt-i and it is not adjustable unless you have a standalone computer on the car. you will also get less horsepower by adjusting the vvtl-i which is what the gts has
eric_m
79
Mar 17, 2013 12:21 AM
kshymkiw
26
Nov 5, 2009 09:14 PM
vintage42
Feb 3, 2007 05:06 PM
TrueSlide
32
Feb 1, 2007 01:07 AM
solotc
May 15, 2005 03:10 AM
