xA/xB XRS swap
Old Feb 24, 2005 | 12:29 AM
TimmyT's Avatar
Scion Society
Default xA/xB XRS swap
I was wondering if any of you xA/B guys have done or thought about swapping an XRS engine with the stock. I was thinking about buying an xA and doing an xrs swap. To me that would seem to be one of the first things i would do for mods. I didn't research it much. But would the 1.8 vvtl-i engine fit in an xA/B engine bay? Are the motor mounts in similar spots or would you need to grind and fabricate? Just curious. any responses would be appreciated.
Old Feb 24, 2005 | 12:42 AM
unlmtdndeavor's Avatar
no it has not been done, but it has been dicussed. yes, the engine can fit..there would need to be new mounts and 4-6" of frame cutting due to the tranny. and good luck finding the complete swap for under 3k
Old Feb 24, 2005 | 01:38 AM
Just use the 1zz 5spd tranny and it'll bolt up fairly easily. the xrs is 2zz. 2zz's in complete form are quite expensive, 1zz's are cheaper and more plentiful. Or you can make a 3zz whcih is the 1zz block with 2zz head.
Old Feb 24, 2005 | 01:42 AM
xmetalx's Avatar
1zz is the only reasonable swap right now, the 2zz requires alot more work
Old Mar 2, 2005 | 10:43 PM
its not THE only reasonable swap. there are others out there...just keep an open mind
Old Mar 3, 2005 | 07:40 AM
showpaojoe's Avatar
IV ACE
Somebody lock this...it's just a 2zz thread in disguise
Old Mar 3, 2005 | 07:52 AM
djct_watt's Avatar
Team Sushi
Are you sure about that? From my information resources, the 3zz is a japanese engine (no longer used USDM) for Corolla's. I believe it is a 1.6L engine, DOHC, VVT-I (without lift). It's supposed to be used on lower model Corolla's in Asia.
Old Mar 3, 2005 | 08:06 AM
showpaojoe's Avatar
IV ACE
2zz, 1zz internals
Old Mar 3, 2005 | 08:35 AM
xmetalx's Avatar
i wish the bastards over at toyota just would have spent a few freaking more hundred dollars and given us the damn 1zz. the gas mileage is still what 28 mpg?
Old Mar 3, 2005 | 10:34 PM
Exactly , it'd only cost them like 500.00 more they could charge us like 1,000.00 more and i'm sure that 90% of us would buy it.
Old Mar 4, 2005 | 06:27 AM
agreed
Old Mar 8, 2005 | 08:40 PM
Rion's Avatar
Yeah, except for the fact that this car was designed for the Japanese market and brought here basically as-is to save cost. That kind of works against them tearing the whole car apart to reverse engineer a different engine in it.
It could be worse, we could have gotten the base 1.3 liter!
Old Mar 8, 2005 | 11:54 PM
djct_watt's Avatar
Team Sushi
oh god, not the 1.3! . . . unless it were a turbo starlet motor!
yupinmytC
22
Jul 27, 2024 07:08 PM
yhwhdesign
Jun 11, 2021 03:34 PM
10spokess
14
Nov 7, 2016 02:43 AM
TheGovernmenT
Sep 4, 2015 11:57 AM
StxArOne
Jul 13, 2015 06:25 PM
