Scion tC 2G ICE & Interior In-car entertainment and electronics...
Factory audio wiring
Old Nov 29, 2010 | 11:16 PM
noisy1eh's Avatar
Default Factory audio wiring
Help
I need to know if the factory head unit has a external amp?
Also need the wiring dir for the audio system for i have a Kenwood DNX9960 and need to install it in the wife's car for xmas.
Old Nov 29, 2010 | 11:48 PM
1stOne's Avatar
Yes, there is a factory amp. You need to wire the remote turn on wire from the aftermarket radio to the power antenna wire for the Metra harness (or equivalent).
Besides that, everything else wires direct. So speakers to speakers, power to power, ground to ground, etc.
Old Nov 30, 2010 | 11:51 AM
noisy1eh's Avatar
Default thanks
I didn't know that a metra wiring kit was out for the 2011 TC??
Thanks i will look again.
Old Jun 22, 2011 | 08:30 PM
bigboi18184's Avatar
Sorry to bring up an old thread for my first post but I'm trying to find out what color the wire is for the remote turn on for the factory amp is. I know for its usually blue but wanted to be sure before i take the dash apart.
Just got me the new 2011 TC and have read that without this being wired up with my aftermarket deck the 6.5" in the front doors will not work.
Old Jun 22, 2011 | 09:47 PM
KidJustin's Avatar
DaYUUM/Scion Evolution
blue
Old Jun 22, 2011 | 10:07 PM
Alright just making sure, i knew the aftermarket wiring harnesses were most of the time blue for the remote. Was just making sure scion didn't make it some odd color.
thx for the reply
Old Dec 6, 2011 | 12:59 AM
op4dc4's Avatar
Hi everybody I want to know what connection you make for the 6x9 woofer .Iknow its the blue on the metra wiring but on the oem harness its which color and which plug because there is 4 of them .thanks a lot .
Old Dec 6, 2011 | 10:20 PM
RedDragons's Avatar
70-1761 is the metra part #. Pretty much every toyota made vehicle since 87 uses it unless it was factory amplified 1992 and up. But even some of the amplified toyotas still use the 1761. Here are the wires:
Radio 12V
blue+radio, white 10 pin plug, pin 4
Radio Ground
brown-radio, white 10 pin plug, pin 7
Radio Ignition
yellow+radio, white 10 pin plug, pin 3
Radio Illumination
gray (parking lights); blue (dimmer)+,-radio, white 10 pin plug, pin 10; white 6 pin plug, pin 5
Factory Amp Turn-on
white (woofer amplifier)+radio, white 10 pin plug, pin 9
Power Antenna
red+radio, white 10 pin plug, pin 8
Left Front Speaker (+/-)
pink - purple (mid-range and tweeter)+,-radio, white 10 pin plug, pins 2 and 6
Right Front Speaker (+/-)
lt. green - blue (mid-range and tweeter)+,-radio, white 10 pin plug, pins 1 and 5
Left Rear Speaker (+/-)
black - yellow+,-radio, white 6 pin plug, pins 2 and 6
Right Rear Speaker (+/-)
red - white+,-radio, white 6 pin plug, pins 1 and 3
Center Channel (+/-)N/A
Subwoofer (+/-)
woofer amplifier uses LF and RF for preamp input
Aux. Audio Input Left (+/-)
white - black+,-radio, white 20 pin plug, pins 17 and 16
Aux. Audio Input Right (+/-)
red - black+,-radio, white 20 pin plug, pins 15 and 16
Notes: The woofer speaker wires are yellow - black (LF); red - white (RF) at the woofer amplifier, white 10 pin plug, pins 1 and 5; 2 and 6. The woofer amplifier is under the driver seat.
Old Dec 6, 2011 | 11:20 PM
dm1336's Avatar
If you get the above metra part harness you can just plug it into the harness behind the radio since everything lines up correctly to the right pin.
The 6pin plug is for the rear speakers and the 10pin is the main one. You need both of those in order for it to work. The plugs on the other side is for steering wheel control and avc-lan
The 6x9's won't work unless the amp under the drivers seat is powered on.
This wire handles that:
This wire is blue on the aftermarket harness and decks.
Old Dec 7, 2011 | 12:13 AM
RedDragons's Avatar
And the solid blue metra wire will also power the antenna amplifier. There will be loops going to 2 or 3 different pins on the harness.
Old Dec 7, 2011 | 03:23 AM
op4dc4's Avatar
thansk a lot guys I made it have a nice day everybody.
stillcole
Apr 6, 2015 03:42 PM
NewBox06
Feb 3, 2015 12:36 PM
lunchbx05
Dec 29, 2014 07:53 PM
minter66
Dec 15, 2014 01:45 PM
cwong1001
Dec 3, 2014 03:30 AM
