Help with aligning timing marks on Cams
Old 12-24-2010, 03:36 PM
johnhawkins's Avatar
Default Help with aligning timing marks on Cams
How exactly do you align the timing marks on the camshaft and the caps? Should the marks be aligned at the same time the cam is bolted down? Or can you turn the camshaft after the cams are bolted down? Any info will help
johnhawkins is offline
Old 12-24-2010, 05:52 PM
borderguy881's Avatar
ive always aligned cams while they are still in.. just simply turn em till they are lined and then when crank in TDC u slip on belt/chain
borderguy881 is offline
Old 12-24-2010, 06:44 PM
crush02342002's Avatar
its really not bad at all...done it a few times now.
crush02342002 is offline
Old 12-24-2010, 06:58 PM
youll notice there is 3 marks on the exhaust cam sprocket... one dot has ex by it (exhaust), one dot has IN (intake), then there is a hash mark between them. you want to align the hash mark with the arrow thats located on the first cap for that cam.
on the intake cam you will see a small dot on the face of the cam sprocket, look just above it and you will see a long hash mark. align that hash mark with the arrow on the first cap for that cam.
all this is assuming your crank is set to TDC.
align the gold links of chain (yellow) on these marks. If you dont have the crank set to TDC you can easily find TDC by doing the above and aligning the crank with the third yellow link. there will be a dot on the small sprockets on the crank. third yellow link goes there.
any other questions?
Old 12-26-2010, 02:04 AM
alot easier than I thought I did this today - Although the oil chain tensioner bolt broke before I could even put it in! Know anywhere I can get a replacement?
Old 12-26-2010, 03:28 AM
i have a spare. if you need it fast though id just run out to the dealership
Old 12-26-2010, 04:30 AM
money sent - thanks man
mav261
10
02-11-2015 02:45 PM
eatcrispycreme2
01-30-2015 03:42 AM
kleecker
01-02-2015 08:09 PM
eric_m
79
03-17-2013 12:21 AM
Scionic
39
07-20-2004 02:46 AM
Quick Reply: Help with aligning timing marks on Cams
