wtf is wrong with my sunroof?
Old Feb 24, 2011 | 09:19 PM
tjbartjr's Avatar
Default wtf is wrong with my sunroof?
I think my sunroof is possessed. When I push the button to open it, most of the time I have to hold it down with some force for a couple of minutes for it to open; occasionally, a light touch is all that is needed. It closes with no issues at all. I have reset it. And a few months ago, the whole assembly; motor, rails, glass were all replaced. It worked fine for a few days then, but the problem soon returned. What's going on with this thing?
Old Feb 24, 2011 | 10:38 PM
Spicy_McHaggiz's Avatar
Sounds like its a problem with the actual switch itself and not the sunroof assembly.
Old Feb 24, 2011 | 11:25 PM
Vang2k's Avatar
you took out the negative and put it back in and than try to reset? after doing that close your windows down all the way and hold the buttons. after that close each one and hold up while doing it. if that doesn't work than....i dunno
Old Feb 24, 2011 | 11:32 PM
crg5990's Avatar
he said he's reset it so im guessing thats what hes tried.
to the OP just get a new switch since that seems most likely
Old Apr 2, 2011 | 08:43 PM
tjbartjr's Avatar
The switch does seem to be the most likely culprit. Anyone know how to get it out without taking down the whole headliner?
Old Apr 2, 2011 | 09:33 PM
fewjative's Avatar
I also have a sunroof problem. Mine is a little different then the OP's though. For mine, it opens fine. When I want to close it, if I hold the close button down then it starts closing gets almost to the end and then just re opens its self. If I keep tapping the close button it works though.
Old Apr 2, 2011 | 09:56 PM
RS2_1823's Avatar
^^ same exact thing with mine.. I haven't gotten a chance to clean the track. Also it whistles on speeds 50mph + :/ if I clean the track I hope it'll fix the problem and seal correctly.
Old Apr 3, 2011 | 10:42 PM
crg5990's Avatar
def clean out the track. our sunroofs have a safety feature that they will re-open if they encounter too much resistance. mine did the same thing and i wiped out the track and sprayed white lithium grease (doesnt attract dirt like wd-40) on all the joints and its worked fine since
Old Apr 6, 2011 | 07:00 PM
wizard2788's Avatar
same problem with my tC recently... i cant press lightly and expect the sunroof to open. its no biggie but i want it back to normal as well!
edit: a couple of minutes?!? mine works as long as you press down hard enough, i hope it doesnt get worse!
Old Apr 20, 2011 | 03:10 AM
tjbartjr's Avatar
Soooo yeah... the switch? How to replace it?
Old Apr 14, 2015 | 11:23 PM
mc1114's Avatar
A little JB Weld on top of the buttons will make better contact with the moving exterior part (in the picture, the Weld is on the two buttons that close the sunroof). I had the all too common "opens fine but wont close" issue
yupinmytC
22
Jul 27, 2024 07:08 PM
BlingSlade
Oct 19, 2016 12:39 AM
BlingSlade
Nov 20, 2015 06:56 PM
Klunkerbill
Nov 9, 2015 11:39 PM
Pkdust
Oct 20, 2015 04:27 PM
