2011-____ [ANT20]
problem with HID fogs
Old Mar 31, 2011 | 02:31 AM
goose_119's Avatar
Default problem with HID fogs
alright, so bought a couple kits off ddm, installed headlights no problem, look great
went to install fogs last night, and no light output. did yall have to do anything funny to get em working?
Old Mar 31, 2011 | 03:34 AM
Enzie's Avatar
I actually wanted to know the process for putting HIDs in the fogs.. Cause I want some deep yellow ones instead of PIAAs :D
Old Mar 31, 2011 | 03:42 AM
Iceman04503's Avatar
Did you try reversing the polarity? Take the plug that goes into the ballast and turn it 180 degrees and try plugging it in that way.
Old Mar 31, 2011 | 03:43 AM
goose_119's Avatar
i did, and nothing
Old Mar 31, 2011 | 03:52 AM
tCb00b's Avatar
Use the known good kit (in the headlights) to test the non-working fog light kit. Only work one part at a time, no need to do both bulbs just work on one side of the car as your "test bench." Start with the bulbs, since you know the ballast in the headlights are connected properly you can use them to test the bulbs. Then use the known good bulbs (ones that worked in the headlights first) to test the ballast. Pay attention to how the functioning lights are connected. In the first gen tC I may have had to switch the plug around. Also, check the fuses, may have accidentally popped one in the install process. Hope this helps.
-Rob
Old Mar 31, 2011 | 04:16 AM
user 7208230's Avatar
Are you using a wiring harness with a relay?
Old Mar 31, 2011 | 04:25 AM
Eziekel's Avatar
what kind of bulbs are you using for fogs? i know the H3 ones you need to ground the bulb. but if it's just a 9006/9005, just check polarity.
Old Mar 31, 2011 | 08:44 AM
goose_119's Avatar
our fogs are H11, so im using that kit. and im not using relay harness. from what i understand, factory is wired up for 55w halogens, so i figured 35w hids wouldnt be a big issue.
imma try swapping parts around on heads tomorrow to try and figure it out cuz ddm is giving no assistance
Old Mar 31, 2011 | 04:09 PM
Eziekel's Avatar
yeah DDM is cheap but their service sucks. shipping is slower than most too....
Old Mar 31, 2011 | 09:57 PM
goose_119's Avatar
so i have no idea what i did the other night (im gonna blame it on attempting installing them at 11pm in a slight rain) but theyre working fine. its funny when i turn em on without car running though cuz i didnt use a relay harness so the fogs look like wig wags and alternate for about 10 seconds while warming up
Old Apr 2, 2011 | 05:03 AM
tCb00b's Avatar
The wattage(W) isn't the issue its the current(A) but with the digital slim kits from DDM, their max current is within the rating of the factory system. DDM's service does take a while to get through, they are extremely busy, apparently customs is cracking down on other company's HID shipments which forces more people to use fewer vendors. But that's just something I read on the internet, time will tell whether or not it's true. This reminds me I need to call them for some warranty stuff. Glad to hear you figured it out.
Old Apr 2, 2011 | 05:44 AM
Ordered a couple DDM HID kits last night. Hopefully they are better than the Hidextra kits I got a month back.
Cobra
Scion tC 2G Aero & Exterior
May 30, 2015 07:47 PM
S7ephavs
Mar 22, 2015 12:09 PM
jackthecat52
Jan 12, 2015 02:49 PM
tc_Jake
Dec 31, 2014 01:45 AM
umnitza
Dec 1, 2014 06:26 PM
