Problem Fixed! And no more XB SHOCK!
Old Mar 17, 2005 | 10:43 PM
fachiro1's Avatar
Default Problem Fixed! And no more XB SHOCK!
My overhead video monito came loose so I took it apart and reinstalled it. I forgot to disconnect the battery when I did this and it blew out the fuse marked dome. The stereo, remote locks, and interior roof lighs stopped working.
I drove the car to Home Depot to get some new screws. After reinstalling the monitor, I replaced the fuse with a spare. The stereo, remote, and interior lights are working now, but the car won't start now.
I did pull out the 30 fuse marked ST, which I thought stood for stereo, but it was okay and I put it back in.
Please help! My XB won't start. When I turn the key, I can hear a few clicks and the fuel pump, but it won't turn over.
Thanks for any help people!
*********Update
Okay, got the box back and decided, hmmmmmmmmm....I'm going to reinstall the video monitor myself. So...................1. Disconnected battery 2. mounted the roof plate 3. PROPERLY INSTALLED THE GROUND WIRE 4. Installed monitor
Okay, the interior lights don't work. There are no popped fuses, so I think maybe the bulbs got burned out. However, after properly doing the ground I noticed something big. There was a thread about people getting shocked and stuff upon exiting the car. For some reason, I noticed that after I did the ground, I don't get shocked anymore. Prior to that, everytime I exited the car I got shocked.
Roger
Old Mar 17, 2005 | 11:40 PM
fachiro1's Avatar
Do you think it may be a bad starter? I don't think it is. The car is only 6 months old.
Or mayber a starter fuse? Please help people, I want to avoid towing the XB to the dealer.
Thanks
Old Mar 18, 2005 | 12:04 AM
TheScionicMan's Avatar
Recheck that ST fuse, replace it with a known good item or at least make sure it is seated properly. That's where I would start...
Old Mar 18, 2005 | 12:28 AM
fachiro1's Avatar
Thanks! There are two fuses marked ST. On is a small one that is 30. The other is a big one.
Old Mar 18, 2005 | 02:42 AM
Max's Avatar
Max
Some dealers offer free towing to them, call and ask.
Old Mar 18, 2005 | 11:09 PM
fachiro1's Avatar
Well, I've only read about it, but it happned to me.
Had the Box towed to Longo.............it was a fuse problem. Apparantly, when I was "messing around" with the fuses, I failed to put one back in its correct place.
So..............................Tow fee: 85.00
Fuse: 5.00
Labor: 75.00
One big ___ stupid expensive mistake....................
Lesson, next time, let the pros do it..........................geeeeeeeee.
Rog
Old Mar 18, 2005 | 11:13 PM
Sometimes saving a little money on a DIY project can cost more in the end. i was thinking that when I busted a sparkplug off in my engine...twice! Luckily an easy-out or 2 saved the day. Turns out my torque wrench doesn't register something as low as 13 ft/lbs. Gotta save it for the wheels only...
Old Mar 18, 2005 | 11:41 PM
fachiro1's Avatar
But as a result of this crap, I did learn quite a bit. I had to read up on grounding, the different type of fuses, but in the end, I still had to let someone else fix the problem.
All I had to do was:
1. Disconnect the battery
2. Tighten down and secure the monitor ground.
Oh well.
Old Mar 18, 2005 | 11:55 PM
Daewootech's Avatar
or next time keep track of everything you do, even if its miniscule thing as long as you keep track of what you take out and what you move youll know where you can backtrack in case **** hits the fan.
if you dont know enought about something, i suggest learning and becoming the pro, it will save you 75 dollars each hour you work on your car, i dont know about you, but i dont trust my car in anyones hands but mine.
become a jack of all trades.
Old Mar 19, 2005 | 02:10 AM
fachiro1's Avatar
Yeah, you're right.
Old Mar 19, 2005 | 03:04 AM
pkoule's Avatar
Originally Posted by fachiro1
Tow fee: 85.00
Fuse: 5.00
Labor: 75.00
Rog
Being made to feel foolish for trying: PRICELESS
Don't feel bad, some of the best learned lessons are the most painful.
Just think: You can now help out other people!!
Old Mar 19, 2005 | 03:51 AM
luckydog's Avatar
did you check the battery if you left the battery connected when you took out the monitor you may of let a wire short left eough juice to run pump and make solenoid click but not turn over don't over look the simple stuff
Old Mar 19, 2005 | 05:10 AM
fachiro1's Avatar
Lucky,
I think that's what happened in the first place. I didn't disconnect the battery bfore disconnecting the monitor.
DJ_FroZone
25
May 30, 2019 07:17 PM
randompacking
Jan 28, 2015 11:43 AM
fluxingnation
Dec 26, 2014 04:28 PM
swtbabiboi4u
Oct 13, 2003 04:38 PM
swtbabiboi4u
Oct 10, 2003 01:40 AM
