Resetting ECU?
Old Sep 19, 2011 | 01:55 AM
OzztCRS1's Avatar
Default Resetting ECU?
Does anyone know of a way to reset the ECU? I know some automatic cars have a procedure to do so and was wondering if it can be done to the tC?
Old Sep 19, 2011 | 02:13 AM
Vlad1024's Avatar
Disconnect the battery for a few minutes. What are you trying to accomplish?
XIEmperorIX's Avatar
Take off the negative battery terminal, step on the brakes (drains the power quicker, brake lots use a lot of juice), reconnect battery, start the car and let it idle for about 10-15 min. I could be wrong about having to press the brakes but it worked for me lol eithr press the brake or just leave the battery disconnected for about 15-20min.
Old Sep 19, 2011 | 02:35 AM
LED-Maniac's Avatar
After disconnecting the battery touch the 2 terminals together.
Old Sep 19, 2011 | 02:42 AM
Frizz's Avatar
Team ScionTific
You're retarded and should be banned for a few days for telling someone to do that.
Go find something productive to do.
Scionlife Rules For All Forums
To post here, you agreed to follow these rules...
1. I will keep my posts relevant and helpful.
• Be helpful and do no harm!
• Post that have veered off topic or bashing WILL be locked, split or deleted.
• Do not multipost the same subject on different areas. This is considered Spamming and will be deleted.
• Allowed multipost are Large Events (I.e. HIN etc), threads will be Locked and Linked to the Region or Club.
• Any personal attack on a member will not be tolerated.
OP: Disconnect the -neg battery terminal for 10-15min then reconnect and let the car idle with AC, radio and headlights off for 15min.
Old Sep 19, 2011 | 03:36 AM
whitetc06's Avatar
Shame on you Led-Maniac!!
anyways, the best way to reset is to disconnect the negative battery terminal for atleast 15mins. Then when you reconnect, start the car make sure you let it idle for 15mins also.. meanwhile you can reset the windows and moonroof.
Old Sep 19, 2011 | 08:38 PM
fongyz's Avatar
there is a fuse you can unplug for a few minutes, resets ECU without losing all your radio presets and what not.... and not having to reset your windows!! google up the diagram i forgot it lol
Old Sep 19, 2011 | 10:41 PM
egobuster1's Avatar
yeah you can pull the negative battery cable or like was stated above you can pull a fuse or maybe two i can't remember ever so i never do it but do make sure you just let the car idle and don't rev it or anything
Old Sep 19, 2011 | 10:50 PM
SquallLHeart's Avatar
my first question is... why do you want to do such a thing?
Old Sep 20, 2011 | 01:11 AM
Spicy_McHaggiz's Avatar
The point of pressing the brakes is to use any reserve power for lighting the brake lights, it really doesn't use a lot of power. (Trying to start the car would use far more) Either way, you would still want to wait about 10-15 after doing so to allow the ecu's power to properly drain.
Old Sep 20, 2011 | 02:00 AM
OzztCRS1's Avatar
I know that some cars when you install a new part, a reset of the ECU is required to get the "full effect" of any changes/mods made to the engine/intake. I was wondering if this was also true for the tC? I know that battery terminals can be disconnected for about 15 minutes or so, but that also removes all electronic settings- windows, radio presets, radio welcome message, etc.
Old Sep 20, 2011 | 02:06 AM
OzztCRS1's Avatar
I'll tell you what. For such "great" advice i'll let u try it out and u let me know how that works out for you...
Old Sep 20, 2011 | 02:41 AM
LED-Maniac's Avatar
I'm sorry I meant both cables of the battery, thus having no power hooked up to the system....[take off both negative and positive] So once the battery is full disconnected, you can remove it from the car, if you touch both cables it will quickly drain all voltage and reset the ecu [some is still retained by capacitors throughout the system]. We [ASE techs] do this at my shop all the time to rule out any erroneous SRS or check engine lights. I didn't mean to confuse anyone...I should have mentioned both terminals, i.e. disconnect the battery. There is NO harm =]
Old Sep 20, 2011 | 04:00 AM
What "mod" are you doing? I can tell you the tC will learn dang near whatever your are doing without resetting the ecu.
pro710
Dec 27, 2023 03:34 PM
deademon
Mar 31, 2016 09:25 PM
MeDizzy
Oct 8, 2015 03:31 PM
Klashan
Sep 24, 2015 12:39 PM
paisatronix
Sep 5, 2015 04:13 AM
