Anybody that changed tC gauge colors
Old Mar 24, 2005 | 02:55 PM
JustinWs6's Avatar
Default Anybody that changed tC gauge colors
Ok I beeen looking through all the previous posts and I keep seeing conflicting reports on which leds to use. I'm trying to figure what blue ones are the best to get, where to get them from, and if any are not to dim for the center console. It seems agreed that the PLCC-2 are the correct size. So if you have done this mod (blue) PLEASE list what led's, where you got them, if they were good or matching brightness, mcd's if you know, and also what ones NOT to get. Thanks everyone
Old Mar 24, 2005 | 03:08 PM
ScionDad's Avatar
If you are only doing the Gauge Cluster then these LED's work perfect. Order 1 or 2 extra in case of mistake or non working led.
https://www.lc-led.com/
I also did Blue for the Gauge Cluster and bought my LED's from lc-led. I tried to do the center console, but they don't get nearly bright enough....yet to find a solution.
But, these look sweet in gauges.....bright and deep blue.
Old Mar 24, 2005 | 03:31 PM
mandos's Avatar
Which blue did you use? There seem to be several with varying mcd ratings.
Thanks.
Old Mar 24, 2005 | 03:53 PM
ScionDad's Avatar
Sorry....
https://www.lc-led.com/View/itemNumber/98
Power top blue
Old Mar 24, 2005 | 04:17 PM
mandos's Avatar
Thanks man.
Much appreciated.
Old Mar 24, 2005 | 05:20 PM
JustinWs6's Avatar
so the lc-leds 98's are good but too dim for the center, anybody find ones that aren't to dim yet, or another solution? Thanks
Old Mar 24, 2005 | 06:12 PM
ScionDad's Avatar
Blue appears to be the problem. Red, green, amber, yellow, etc usually operate at 2.2 volts up to 5v. Blue requires 3.3 volts low end and that appears to be a problem for the center column. The guage cluster on the other hand appears to have 3+volts to work with so they look really bright and deep blue/
Many people are trying to find a fix. Ranging from changing out the voltage regulator on the board to inserting a resistor in parallel with the dimming ****...but the last option would mess with the gauge cluster voltage.
Old Mar 24, 2005 | 06:43 PM
jmiller20874's Avatar
ScionDad, could you post a good picture of your console? Since you have the 350mcd one's, they have to be brighter than mine (98mcd). Thanks a ton.
If you have trouble posting here, you can email it to me at jmiller20874@yahoo.com
Old Mar 24, 2005 | 11:29 PM
tckurt's Avatar
N.G.S.O.
How hard is it to install these leds?
Old Mar 25, 2005 | 01:55 PM
If you're decently good with a soldering iron, you'll find the hardest part is taking the dash apart (or the console anyways). It's not really that difficult to do if you have a steady hand.
Old Mar 26, 2005 | 03:40 AM
tckurt's Avatar
N.G.S.O.
hmm well I can but currently do not own a soldering iron anymore... would an audio shop be able to do this?
Old Mar 27, 2005 | 04:42 AM
Just get one from RadioShack, it's only $15 for a 15W-20W model. I doubt an audio shop will do it since they wouldn't want the liability.
Old Mar 29, 2005 | 06:45 PM
JustinWs6's Avatar
well looks like this project will have to be postponed until i find a fix for the matching blues
Old Mar 29, 2005 | 07:13 PM
Mainrodax's Avatar
Has anyone here screwed up their gauge cluster doing this?
Old Mar 29, 2005 | 07:19 PM
kileil's Avatar
In addition to led part #s, does anyone has a pinout diagram so we can benchtest these before reinstallation?
Old Mar 29, 2005 | 07:45 PM
ScionDad's Avatar
The only damage I've heard of is someone breaking their LCD display on the center console. No problems on the gauges. Read the tutorial...it's perfect.
It's really easy guys. It looks scarier than it really is. The needles have a built in stop (I took pics just to be safe BEFORE I took needles off).
As for a pinout, nope not that I've come across. When I changed them, I kept taking it out to the car and just plugging in the gauge and turning the key to light it up. Oh and make sure you turn the key ALL the way to acc cause some of the lights only come on in this position....I resoldered a few thinking I messed them up.
MonsterunderBed0
Feb 17, 2015 08:42 PM
mattjk
121
Dec 22, 2004 10:49 AM
DR_xB
Jul 20, 2004 08:31 PM
DirtyThirty
14
Jan 16, 2004 04:48 AM
kagero79
Nov 24, 2003 09:23 PM
