Scion tC 2G Suspension & Handling Coilovers, Shocks, Airbags, Swaybars...
Tien lowering help fast....
Old Jul 7, 2012 | 11:30 PM
MnMs's Avatar
Default Tien lowering help fast....
I got tien lowering springs and at high way speeds I hear rubbing..anyone know solve this?...fyi I'm 6 hours from home and about trailer it back if I can't find problem or fix
Old Jul 8, 2012 | 01:32 AM
Jon's Avatar
Jon
Moderator
Moderator
Rubbing won't hurt if that's indeed what it is. Unless it's constant tire on fender contact. If that's the case, you must have either installed them incorrectly or severely threw your alignment out of spec. On stock wheels, you should still have some wheel gap.
Old Jul 8, 2012 | 01:38 AM
MnMs's Avatar
I think I figured it out. 6 hour drive with lots of rubbing. Not constant but no tire rubbing makes. I think plastic loose and that what I keep hearing cause its only at 65+ MPH or/and bumps or turning drive er tire inward on a turn. Hopefully thy it NZ simple fix
Old Jul 8, 2012 | 06:00 PM
jngox3's Avatar
I had the same thing, On S-Techs. Mine were to tight, you absolutely need a torque wrench and go to exact manufacturer specifications. It can cause a lot of stress to the rest of the suspension system if it's not correct.
Old Jul 8, 2012 | 07:12 PM
MnMs's Avatar
All my rubbing is plastic in fenders which hopefully zipties fix
Uhhtomik
Scion tC 2G Wheel & Tire
May 19, 2015 04:20 PM
Kik
May 10, 2015 12:36 AM
sciontcguy15912
Mar 21, 2015 08:04 PM
jspadaro
Mar 11, 2015 06:04 PM
viciouzgamer
Feb 18, 2015 03:26 PM
