Tien lowering help fast....
I got tien lowering springs and at high way speeds I hear rubbing..anyone know solve this?...fyi I'm 6 hours from home and about trailer it back if I can't find problem or fix
Rubbing won't hurt if that's indeed what it is. Unless it's constant tire on fender contact. If that's the case, you must have either installed them incorrectly or severely threw your alignment out of spec. On stock wheels, you should still have some wheel gap.
I think I figured it out. 6 hour drive with lots of rubbing. Not constant but no tire rubbing makes. I think plastic loose and that what I keep hearing cause its only at 65+ MPH or/and bumps or turning drive er tire inward on a turn. Hopefully thy it NZ simple fix
All my rubbing is plastic in fenders which hopefully zipties fix
jspadaro
Mar 11, 2015 06:04 PM
viciouzgamer
Feb 18, 2015 03:26 PM
