2AZ-FE / TC ECU PINOUT?
Old 06-23-2005, 10:51 PM
SSR_Engineering's Avatar
Default 2AZ-FE / TC ECU PINOUT?
We're looking for the TC Tach Signal Wire, does anyone have a diagram, or wire color for the ECU tach signal wire?
SSR_Engineering is offline
Old 06-24-2005, 12:05 AM
matty-tC's Avatar
do you have a copy of the FSM?
matty-tC is offline
Old 06-24-2005, 12:08 AM
aarontrini85's Avatar
it is a black wire going to the gauges its on the far left when you take of the harness from the gauge pod atleast i think it is. its been a while since i hooked up the rsm
aarontrini85 is offline
Old 06-24-2005, 12:27 AM
It's supposed to be on the Inside plug of the two plugs on the top or the right if the ecu is laying flat. And it's supposed to be the top right pin, which it's not
[{ }{ }{ }==={ *}{ }] <--- if thats your ecu those are the 5 plugs im talking about and the asterisk is the pin it's supposed to be
Where can i download the FSM?
Old 06-24-2005, 12:49 AM
matty-tC's Avatar
it was on the forums somewhere. try a search. if you can't come up with it, send me a message and i'll see if i can zip and e-mail it
matty-tC is offline
Old 06-24-2005, 01:05 AM
jeremyc's Avatar
If you dont want to go to the gauge cluser you may want to try the data link conn. under dash, pin 9. Its black
jeremyc is offline
Old 06-24-2005, 01:24 AM
matty-tC's Avatar
i can't get the FSM to upload or e-mail. my home connection sucks.
sorry man
matty-tC is offline
Old 06-24-2005, 02:50 AM
Joe_Dezod's Avatar
Here I come to the rescue! Hopefully this solves your problem. I'm not 100% sure on the color of the wire, but I know that's the spot for it. Good luck.
Joe_Dezod is offline
Old 06-25-2005, 03:58 AM
Joe_Dezod's Avatar
Has SSR seen this yet?
yupinmytC
21
11-08-2019 09:34 AM
drgonzo92
14
04-24-2019 07:27 PM
krazylowgsx
Scion xA/xB 1st-Gen Forced Induction
12-18-2016 04:13 AM
deademon
03-31-2016 09:25 PM
mikeytomas
08-06-2015 08:54 PM
Quick Reply: 2AZ-FE / TC ECU PINOUT?
