LOUD thump in hard acceration, engine mounts?
Old Apr 1, 2004 | 08:04 AM
Radiodude's Avatar
Default LOUD thump in hard acceration, engine mounts?
I am still babying my RS1 but to be honest I have reved it up twice (not redlined though) and dropped the cutch to see what she would do...... and both times I have heard and preculiar HARD thump.
I was curious as to if this was normal. This is my first FWD manuel tranny car so maybe im just ignorent. It sounds as if the engine mounts or tranny mounts are loose/ broken or at the very least, VERY VERY weak. The loud thump (my friend describes as metal to metal) usually knocks stuff off the dash board. Could it be that I do have faulty or broken engine or tranny mounts or is the little box just tell me it isnt made to handle such acceration. Help please!
Thanks
-will
Old Apr 1, 2004 | 11:26 AM
superjeer's Avatar
Yeah, I would check that out..
I broke the engine mounts in my truck, but that was easy to tell because the tree for the AT shifter would jump up and slam down. So, if you dump the clutch, you might be able to see a lot of movement with your shifter. BUT, I think you'd better get in there with your eyes and take a look.
Must've been a monday, everyone's hung over and forgot some mounts! There's prolly a bud can in your door too.
Old Apr 1, 2004 | 06:10 PM
XBman's Avatar
Yeah it could be those. I had to change the mounts in my ford festiva a while bcak b/c they where rustin out lol. anyways i wouls definatly check em out
Old Apr 9, 2004 | 09:40 PM
boxman94561's Avatar
if you rev it up to high and dump the clutch that is a lot of pressure being put on the tranny. You got your vehicle weight plus occupants and then the tourque of the engine. My Acura did it all the time and when i had that stuff checked out they said there was nothing remotley even looking wrong with any mounts. Just dont do that stuff to often or you might drop your tranny or shatter the clutch
Old Apr 15, 2004 | 03:27 PM
Sciomodr's Avatar
Default Re: thump
If it was revved and the clutch dumped it most likely would be wheel hop. A common side effect of front drive cars due to weight transfer coming off the wheels upon acceleration. AWD cars get it too though. Work on your launch technique and it should disappear.
Old Apr 18, 2004 | 05:48 AM
ncscion's Avatar
Default Re: thump
this is what it is. every fwd car i have owned has had this problem. i like you have done the same to my xb and the same has happened. its nothing you need to worry about, but try not to be so hard on the girl she's new man. you gotta break her in
greddy05tc
Jan 27, 2015 12:09 PM
mw1957
Jan 14, 2015 01:06 PM
MosFed
Dec 27, 2014 03:24 PM
fluxingnation
Dec 26, 2014 04:28 PM
BlueBox
18
Nov 30, 2003 11:04 PM
