Engine light on?
Old Apr 7, 2004 | 06:47 PM
justchico's Avatar
Default Engine light on?
Over the weekend I was messing with my engine on my xB and look what happened. My engine light is on. I have read in here some were how to turn the engine light off but can't find it. I have tried disconnecting the battier for 5 sec but that didn't work. O and the VSC and TRAC off lights are on. Am I just screwed or what? Please help.
Old Apr 7, 2004 | 06:51 PM
BlueScionXB's Avatar
What were you doing to the engine?
Old Apr 7, 2004 | 06:59 PM
justchico's Avatar
I found a performance module and tried to install it. Put it in, car ran like crap, maybe choose the wrong wires? Took the module out, car runs fine, lights are on.
Old Apr 7, 2004 | 07:04 PM
sithscripter's Avatar
It takes more than 5 seconds to clear the computer settings. Try 10-15 minutes to be sure.
Of course you'll lose the trip odometer settings, time and all head unit presets including SSP
ShadowMage's Avatar
you mean one of those performance modules off of ebay?
Old Apr 7, 2004 | 07:08 PM
justchico's Avatar
Fully disconnect the battier, both + and -? Did I say 5 sec, I meant 5 min. Yes I got it from ebay. But I can return it if it doesn't work.
Old Apr 7, 2004 | 07:14 PM
ShadowMage's Avatar
well then no offense but that was your first mistake right there, buying one of those performance modules from ebay. Those are just a major rip off. And I think you probably are pretty much screwed, if you can't fix the problem yourself. They don't warranty stuff that was messed up by aftermarket products.
Old Apr 8, 2004 | 05:46 AM
XBman's Avatar
yup
Old Apr 8, 2004 | 05:50 AM
westsype's Avatar
Duh there is a reason they are 20 dollars or so I have this spoiler and it gives major down force and adds an extra 20 ponies would u like to buy it :?:
Old Apr 8, 2004 | 06:10 AM
Djuan's Avatar
Default anyone anyone
well maybe someone on here could give some good advice, not just rag on somebody for buying some crap...
Old Apr 8, 2004 | 02:41 PM
justchico's Avatar
We learn from other peoples mistakes, right. That's why this forum is here. So, how about something helpful to get the problem sovled. :D
Old Apr 8, 2004 | 02:44 PM
westsype's Avatar
Well here some advice don't buy crap on ebay if it is to good to be true.
Old Apr 8, 2004 | 02:46 PM
PRESTIGEScioN's Avatar
theres your answer...what did you spend? $20 for 20hp too good to be true brotherman
Old Apr 8, 2004 | 05:12 PM
justchico's Avatar
In conjunction with disconnecting the battery, are there any solenoids or fuses that I should pull out to reset the computer to get the VSC, TRAC off, Engine check lights off? Just disconnecting the battery for an hour does not seem to work. Are there battery backups for the computer and how long does it take for them to discharge?
Old Apr 8, 2004 | 05:35 PM
JDMbB's Avatar
all those lights turned on for me once when i disconnected the MAF sensor. they didnt turn off for a long time. it could probably be that. check the connection and reset the ecu.
Old Apr 8, 2004 | 05:40 PM
justchico's Avatar
Do you know how long the lights stayed on for, weeks, month, days? Do you know the proper way to reset the ecu. Everyone so far has liked ripping me a new hole. :twisted:
Old Apr 8, 2004 | 05:53 PM
JDMbB's Avatar
it was only on for about 2 days. and that was because i didnt have my car on ,so the computer took long to reset itself. my dealer told me just to drive around or leave the car on and the lights should come off. if not, your gonna have to take it in to get serviced.
Old Apr 8, 2004 | 06:02 PM
justchico's Avatar
The lights have been on since Tuesday. But my drive to work is only about 5 mins. Maybe that's not enough time for the computer to check itself. I'll be driving it over the weekend more, hope the light turns off. If the lights don't come off by next week I'll probly turn it in and hope not to get dinged by the dealer. :oops:
Old Apr 8, 2004 | 06:05 PM
All that "performance (ya...right) module" does is places a reistor that you can buy at any local radio shack somewhere along the wiring of the ECU...what it does is tricks your ECU into thinking that your intake is sucking in cold air, when in reality it is sucking in hot air...obviously this could present quite a few problems...your engine thinks that it is taking in cool air which it is not, which could result in the engine generally overheating...etc...So I'd be careful with such products...they might work now...but just think about how they are going to effect your engine in a few years...I would be skeptical about any perfomance mod that is that cheap and non-name-branded...
We all have made mistakes in our lives, but the thing to do is to learn from others experiences...not poke fun at someone else...because I can assure you that someone else will be back here with the same exact problem because he didn't care to read or ask of others experiences...
Best of luck justchico...
Old Apr 11, 2004 | 04:26 AM
justchico's Avatar
Thanks . I am getting a refund for the module and the dealer is going to reset my ecu. I have learned my lesson and should have posted a question about the module on the forum before buying it. My xB runs great and you can't even tell I got into the wiring harnes.
Jordly221
Feb 13, 2019 05:29 PM
Miqmiqmiq
Apr 16, 2016 02:34 AM
daniinpitt
Apr 4, 2015 08:07 PM
AdmirN
Jan 5, 2015 10:19 PM
Hardhitten
15
Nov 24, 2003 05:38 PM
