OBD3 and other warrenty voiders
Old Apr 13, 2004 | 08:50 PM
MotoMan_YZ400's Avatar
Default OBD3 and other warrenty voiders
OK guys at work told me that all new cars come w/ OBIII that logs your driving. I have heard of someone w/ a newer BMW taking his in for a small warrenty repair and they told him NO b/c he took it out on the track! Well i guess what i'm asking here is I tend to skip off the rev limiter sometimes and also pull some high G turns while heal towing, will any of this show up in my ECU and void my warrenty? And also whats this i hear about any after market (including TRD) if not installed by Toyota sertified pros voids warrenty? Can they keep take if they installed it or not? I paid the extra $1k for the extended warrenty and i want to keep it! :?:
Old Apr 13, 2004 | 10:31 PM
Tuner's Avatar
OBDIII is not out yet
Old Apr 13, 2004 | 11:24 PM
TheScionicMan's Avatar
If your TRD extras are installed by a certified tech at the dealer, they will be covered under the Scion warranty. If they are installed elsewhere, only the TRD warranty applies.
If you go aftermarket parts, obviously Scion's not going to warranty them. If your aftermarket springs break, any damage caused WILL not be covered by Scion.
If you put aftermarket springs on and you have an unrelated problem, like an engine problem, the springs won't affect your warranty. They have to be able to prove that it was caused by the aftermarket parts. Now if it's an intake and you have engine troubles, you may get into a gray area there...
Does this make sense?
Old Apr 14, 2004 | 08:58 PM
TheDanger's Avatar
Scionicman Ive seen you post that about a 100 times now...you should change your name to the Warrantyman..j/k
Old Apr 14, 2004 | 09:07 PM
Mr_scion's Avatar
N.G.S.O.
your best bet is to ask your dealer first b/c some are _______s about that stuff and u have to call scion and toyota its just a big mess even if everthing TheScionicMan said is turn the dealer still can say no
Old Apr 14, 2004 | 10:30 PM
George's Avatar
Default Re: OBD3 and other warrenty voiders
Originally Posted by MotoMan_YZ400
OK guys at work told me that all new cars come w/ OBIII that logs your driving...
The "guys at work" are wrong. Scions are OBDII.
Old Apr 15, 2004 | 01:19 AM
its_ikon's Avatar
this will answer the warranty question
https://www.scionlife.com/forums/viewtopic.php?t=7518
Bmfxtreme
Jun 22, 2015 02:25 PM
shane_reid
Apr 16, 2005 12:27 AM
Chimmy3
Feb 3, 2005 04:27 PM
Az_Scion_tC
Sep 16, 2004 09:56 PM
MotoMan_YZ400
May 17, 2004 02:22 AM
