Can yall help?
Old Jul 5, 2004 | 03:59 PM
XBoy's Avatar
Default Can yall help?
I got my Scion about 7000 miles ago and the thing is awesome. However I've been hearing sort of a "chirp chirp chirp" sound when I am making tight turns at moderate speeds. I think it might be a loose belt... any ideas?
Old Jul 5, 2004 | 04:05 PM
xboxPS2's Avatar
Default Re: Can yall help?
well you should be going to get a free oil change pretty soon so i'd ask them to look at it while ur in there....if they say "well that'll cost $75 to look at" then tell them to shove it and say "umm no if there's something wrong it under warranty so fix it"
Jeff
Old Jul 5, 2004 | 04:09 PM
fr130's Avatar
You're probably running on stock tires? The stock tires suck. Or VSC is working, thus the chirp.
Old Jul 5, 2004 | 04:13 PM
XBoy's Avatar
I thought it might be the VSC... That would make a chirp?? And yes I am still running stock tires Shame on me
Old Jul 5, 2004 | 04:22 PM
xboxPS2's Avatar
the vsc is a beep on the interior....u sed something about a chirp in the engine
idk do as u wish
Jeff
Old Jul 5, 2004 | 04:28 PM
XBoy's Avatar
Its an audable chirp from outside the car...it sounds like there is a damn bird in my tire
Old Jul 5, 2004 | 04:32 PM
XBoy's Avatar
Its not just a single chirp its a rythmic "chirp-chirp-chirp" I'm baffled and I hate going into the dealer with out some idea of what it might be. Any help is greatly appricated. :D
Old Jul 5, 2004 | 04:49 PM
xboxPS2's Avatar
def not vsc then vsc is more of a beep beep beep beep beep not tires that would be more of a squeal that'd be cool if u oculd strap urself to the engine bay and look while it happened....
it could very well be a belt maybe brakes? does it happen any other time? do u drive fast and brake hard?
Jeff
Old Jul 5, 2004 | 04:53 PM
XBoy's Avatar
I dont usually break that hard... but I average about 80 on the freeway... how doesnt right? It only happens when I am making a moderatly sharp turn. Its not a squeal... But its not coming from the inside the cabin
Old Jul 5, 2004 | 05:50 PM
CBSIMONSEZ's Avatar
It sounds like to me that you may have a build up of brake dust on the stock wheel. Remove the hob cap and wash the wheel off. If you see some spots where the factory black paint has worn away, and is possibly starting to rust, then its probably your hub caps. Because when you turn, your flexing the wheel, and this rubs against the holding clips on the hub cap. If out of all the holding clamps there is one that is rubbing against bare metal, then this is the cause of the "chirping" sound.
Old Jul 5, 2004 | 06:05 PM
XBoy's Avatar
Thanks! that sounds very possable. I am taking it in tommorrow for its 7500 mile check up. I'll keep you guys posted on what it is incase you need to look out for it
Old Jul 5, 2004 | 06:19 PM
xboxPS2's Avatar
good luck with it
Jeff
babii_07_tc
May 7, 2015 04:06 AM
RainbowRhonda
Regional - Deep South
Mar 9, 2015 05:14 AM
J_A_Trevino
36
May 29, 2005 09:07 PM
wowguytc
15
Apr 28, 2005 03:27 PM
emsdude
Apr 3, 2005 12:56 PM
